Question about Dell Televison & Video
Having trouble , no picture when i turn the set on
I cann hear the set turn on but i get no picture, this just happen all at once, the set is less than 3 years old
    Sergeant:
    Champion:
  • 267 Answers
Hve it checked by a servicer. If you hear the relay click on you probably have a power supply to the inverter board a bad inverter board or a bad panel.
Posted on Apr 24, 2009
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
I have a problem i can hear the person im talking to but they cann hardly hear me im very distant very low volume ii have a lg 500
Hummm, we would kind of need to know WHAT you are using, so I guess Skype. Try turning off auto gain on your microphone.
Jun 04, 2011 | Computers & Internet
My ps3 will boot up and the green light is on but i cannot see what is being displayed. i once changed the settings from the three prong to HDMI cable and since then i have not been able to view anything...
1. Turn off the PS3
2. Plug in whatever cable you are going to use
3. Hold the power button down until it beeps once followed by two quick beeps
This resets the display settings to defaults and you will see the picture again.
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
No picture have sound will power on/off
Hi! the trouble you have mentioned indicates that your lcd back light is not functioning. i think the inverter circuit is in trouble or malfunctioning. usually you could re solder it or replace it with a new. the inverter circuit is the one responsible in turning your back light on.
Sep 19, 2009 | Vizio GV47LF Television
Blurry pictures after I have had no trouble in the past
If this is happening only in low-light situations when the flash is not on, check your manual to turn the camera's high-sensitivity feature on. Or change the ISO to the highest setting (1000 is good) for these pictures. That should reduce blur and shake. Of course, putting the camera on a tripod or beanbag, or resting your elbows on a solid surface, will have the same effect.
Jun 05, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
2008 honda odessey ignition switch trouble
Hi
I have same problem - intermittently in my 2005 Honda Odyssey (Australian Version)! Same story with dealer response since of course it will not do it when I take it in (twice). Honda dealer says he cannot repair problem unless he sees it is broken! Very frustrating!!!!
I have had some success by putting the key in and out of lock several times and then moving it about when I try to start the car - normally this fixes it. I only hope this does not break permanently when I am far from home!
Keen to hear if others have this problem and have found a permanent solution.
nmb
Apr 07, 2009 | Honda Odyssey Cars & Trucks
Blurry pictures
Both of these problems are caused by underexposure. There are several causes for this. If you are set in AUTO MODE check the shutter speed and lens opening in the view finder. If the speed is less than 100 and the shutter is less than 5 and you are not using flash. You will probably get blured and dark pictures.  Practice shooting with your settings outside in sunlight , inside with lamplight, inside with flash and all of the above with motion. Check the exposure after each shot and make adjustments. In a short time you will get very good at setting your camera.
Dec 09, 2008 | Nikon D70s Digital Camera
PS2 screen won't show on tv set to game
try to trouble shoot if the wire is the problem, how? remove the 3 colored wires from the tv and ps2 then try to use the red color instead of yellow to the video from tv and ps2 (both red) temporarily do not use the yellow color. once a picture appears use now the white for the audio (both white) for left audio once there is a sound you may try the yellow for the right audio. i hope this will help you and hear a positve reply from you.
Dec 03, 2007 | Sony PlayStation 2 (PS2) Console
Not focusing
Do you hear any unusual friction noise while the lens assembly projects out.. if so then the traction assembly of your zoom barrel has developed mechanical obstruction, in which case it has to be serviced. Take it to the service centre and the problem will be solved. If the zoom assembly does not fully extent to its homing position, the camera retracts and lens and powers itself off. Enjoy
Aug 16, 2007 | Olympus FE-230 Digital Camera
Motorola Ming Speaker
hi, it seems u r facing some trouble while receiving calls,. well, there's no such optional setting which would turn the flip speaker on/off,.. hence its clear that the prob is with the flip, my best advice is to give it for an authorized Motorola service center (as your phone comes under the warranty period i guess), and wait for the best to happen,.. regards, sheldon
Aug 03, 2007 | Motorola Mobility MING A1200
Televison & Video Logo
280 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
