Question about Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Need to clean keyboard
I spilt wine on the key board (aaagggh). I have lost the use of some of the keys: 6, l, 0, ' and a. I tried to unscrew the computer to see if I could maybe remove and clean the keyboard but have only got as far as taking all the screws out. Can I take out the keyboard and clean it? The model is Fujitsu Siemens Lifebook T4220. Any help appreciated!
    Scholar:
  • 103 Answers
Hi yes you can clean the keyboard. i am placing three website links which clearly tells the steps to clean a keyboard
http://www.compukiss.com/care-maintenance/clean-the-keyboard.html
http://www.helpwithpcs.com/maintenance/cleaning-keyboard.htm
http://www.pcworld.com/article/112041/stepbystep_keep_a_clean_keyboard.html
here is another link which has a video about cleaning the keyboard.
http://www.ehow.com/video_2026_clean-computer-keyboard.html
Hope this website link be useful.
Posted on Apr 17, 2009
Why aren't detachable keyboard keys a/z/q working?
I can only guess but sounds like you need to buy a new keyboard .
Dec 30, 2015 | Tablets & eReaders
My daughters home page on her irulu 7 inch tablets is typing by its self. How do I stop it so she can enter her password
Hard Reset the tablet by holding the power on off whilst holding the volume down button until machine switches off, then restart.on some machines it may be volume up instead, others it will be the home button and power button.this should reset tablet to default settings.If it continues to play up then it is likely the touch digitizer is faulty.if you are trying to use a USB keyboard disconnect it before doing any of the above then once tablet is running reconnect the device.it could be the USB keyboard that has a key stuck down due to spilt drink or food.hope this gives you some pointers.
Jan 24, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
Hi I purchased a tablet on line. I received it just the day before yesterday and noticed that a couple of keys on the key board don't work. The tablet seems fine. What do I do. Very disappoint
What make and model of tablet is it that you have the problem with? Is the keyboard Bluetooth or USB or direct-connect? What keys aren't working vs keys that are working? You have to supply some minimal information to help us help you. If it is a Bluetooth keyboard, make sure it's battery is charged.
Dec 04, 2014 | Tablets & eReaders
Changing keyboard on Fujitsu T5010
Remove the square screw covers above the keyboard on either side of the swiveling screen hinge. Unscrew the 2 screws and use a small flat head screw driver to remove the plastic cover above the keyboard. Do this by inserting the screw driver underneath the plastic cover near to the f keys on the keyboard and gently pop the cover off. Carefully remove the ribbon from the motherboard, use a small screw driver to release the clip that holds the ribbon in place (ribbon located above f3,f4 keys). Slide the keyboard up and it should release if it doesn't then there may be some sticky tape holding the keyboard down, this is located behind the f2,f3,f4,f5 keys, carefully pull the keyboard away but hold the keyboard by the f keys so that you do not damage the keyboard by bending it. Reverse the procedure to fit new keyboard
May 28, 2010 | Fujitsu Siemens LifeBook T5010 Tablet PC
Toshiba Portege 3500 keyboard not responding
Well, yes you do have another option.
Just press and hold the CTRL key and press the K key that should help you with your concern. If call the Toshiba hotline 1800-457-7777 to send your NB to the DEPOT.
Aug 21, 2009 | Toshiba Portege 3500 Tablet PC
Toshiba R100 keyboard not working
I did the same some two years ago, with the R100 on. I switched everything off, dismounted the computer body (not the screen)up to the last screw, and dried that sweet coffee from everywhere where I found it. Mostly this was the keyboard and mouse. The motherboard is luckily protected by some plastic sheet.
Regarding the keyboard, after disconnecting it from the motherboard, I washed it completely under flowing water and then let it dry for several days. In the meantime, I used a USB one. Since then, I used the same keyboard for two years until now, when it died, apparently rather from some motherboard-related reason than water. So I think - you may get a new keyboard, but if youre lucky, you may as well revive this old one.
Jan 07, 2009 | Toshiba Portege R100 Tablet PC
TC1100 keyboard replacement info
If you are replacing the keyboard component (i.e. the actual keyboard) the process is straightforward. You will need jeweller screwdrivers as the srew (torque and philips are quite small):
1. remove all outside screws on the back of the keyboard
2. as per wkuk above you (thanks!) you will see 4 small covers
3. Pop the covers off with a pin they are lightly glued on
4. Remove the 4 screws (philips head)
5. Turn the keyboard so the keys face the table
6. Separate the case exposing the back of the keyboard
7. There are two screws that need to be removed that hold the keyboard in
8. Remove the tape that holds down the ribbon cables
9. Two ribbon cables attach the the keyboard. Be VERY careful and disconnext the slim one from the existing keyboard. Disconnect the second cable from the keyboard body (as the kew keyboard will plug in there.
10. Remove the keyboard and replace with the new keyboard
11. Reverse the steps above.
The real key is to be careful with the cables. Hold the entire cable firmly as these types of connectors can tear. When you initially slowly remove the cables you will gain some idea of how far the cable goes into the connectors. Although I've done lots of fixes on hardware this was my first time doing my keyboard for my TC1100 and the start to finish was 15-20 minutes. If in doubt, take a phot of the keyboard after you've removed the keyboard.
Cheers,
David
Jun 09, 2008 | Compaq tc1100 Tablet PC
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Jan 16, 2008 | Toshiba Portege M400-S5032X Tablet PC
Key board problem
check you keyboard in Regional settings and see that it is set to a 101 type (US or Aust) otherwise key location can change,also are you talking about Shift Keys or the Up/Down, Left/Right scroll arrows, let me know, otherwise something has gone arye on the keyboard itself.
Dec 12, 2007 | Compaq tc1100 Tablet PC
Viewsonic Tablet PC keyboard issue.
may be the best solution for this problem is consult your hardware manufacturer and ask him to replace the motherboard, if the pc is under warranty they will replace it for free of cost.
Apr 05, 2007 | ViewSonic TPCV1250S (TPCV1250S0103) Tablet...
Fujitsu Siemens LIFEBOOK T4010D Tablet PC Logo
520 people viewed this question
Top Fujitsu Siemens Tablets & eReaders Experts
Martin Murray
Lakshman P
fyigen
Are you a Fujitsu Siemens Tablet and eReader Expert? Answer questions, earn points and help others
