Question about Sony XPLOD CDX-GT200 CD Player
How do i change illumination
I have been trying to change my head unit from red illumination to green any help would be great cheers
  • 15,935 Answers
CLICK HERE for your owners manual in PDF format.
This is not a selectable menu option built in the radio. You may take it to a repair shop and they can change the lights inside the face if you choose to have another color.
Thanks for using FixYa - a fixYa rating is appreciated for answering your FREE question
Posted on Apr 17, 2009
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
I have a 1991 ford festiva i changed my radio and now my shifter and my dash lits dont work are they wired in with the factery radio
Hi, the factory radio uses the illumination wire, but the aftermarket radio does not. You have to make sure that wire is taped off so it doesn't short the illumination circuit. Check your tail lights fuse. If it's blown, pull the head unit and disconnect/tape off the illumination wire (blue with a white stripe) from the factory harness. Then put in a fresh fuse. If you have more questions, please specify the model of the head unit.
1991 Ford Festiva Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Red/Black
Car Radio Illumination Wire: Blue/White
Left Front Speaker Positive Wire (+): Blue/Red
Left Front Speaker Negative Wire (-): Blue/Yellow
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Blue/White
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Nov 21, 2011 | Car Audio & Video
How do you switch the illumination color from Red to Green on the pioneer deh-2200ub
Actually you can change the color. Turn the Unit off. Press and Hold MC. The menu will pop up, turn to Ilumi turn it to desired color. It only comes in Red or Green.
Aug 15, 2010 | Pioneer DEH2200UB with iPod Direct Control...
I just installed the unit, It gets station info, but no sound?
Hello! Check the vehicle's wiring to the new unit...
Ford wiring
Constant +12volts Green/Yellow.............+12volts with key off
Switched +12volts Yellow /black...............Ignition Sw.
Ground Red...............unusual but true
Illumination Blue/Red.................Radio lights
Send a comment.....I am here!...........saailer
Jan 22, 2010 | Pioneer GEX-P10HD HD Radio Tuner for Head...
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
In need a wiring diagram for a clarion vrx745vd head unit
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Aug 30, 2009 | Clarion VRX745VD Car DVD Player
2001 Ford E-150, year 2001, wire harness connection
As for the head units leads they should be marked or identified in the installation manual. There are but only three wires here that I might be able to help you with.
Two of the wires should have in-line fuse links (12+ volt power) and they are the constant feed (for memory) and the switched feed (for operation). The ground lead is typically solid black.
This is a general factory radio color code. Wire colors in your car might be different than colors described here. Use the given colors for reference purposes only. Always test wires to make sure they are correct.
Good luck
Aduz
FORD P o w e r Memory (+12v Constant) Green Yellow Ignition (+12v Switched) Yellow/Black Ground (-) Black or Fat Red Illumination Orange Dimmer Orange/White Power Antenna Blue (varies greatly) S p e a k e r s Right Front (+) White/Green Right Front (-) Green/Orange Left Front (+) Orange/Green Left Front (-) Light Blue Right Rear (+) Pink/Blue Right Rear (-) Green/orange Left Rear (+) Pink/green Left Rear (-) Pink/Blue
Mar 28, 2009 | Car Audio & Video
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Jan 10, 2009 | 2000 Nissan Sentra
Car stereo illumination colour
there are two versions of that radio. your version does not have a color change option. here is the manual for it. https://esupport.sony.com/US/p/model-home.pl?mdl=CDXGT310&template_id=1®ion_id=1&tab=manuals#
Jun 06, 2017 | Car Audio & Video
Sony XPLOD CDX-GT200 CD Player Logo
277 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
