Question about Epson Stylus 1400 InkJet Photo Printer
Blinking lights I have an Epson Photo 1400 ink jet printer. the paper and ink lights are blinking simultaneously. I think it might be the ink pad. can someone tell me how I can fix this on my own. On my old 1280 I used dab the pad with a paper towel and reset the printer. Will it work for the 1400? Any help will be great. Thanks!
  • david041164 Apr 17, 2009
    Hi, sorry I meant alternately. The power light is on and not blinking.
  • adi May 11, 2010
    when the error occurs that you change the pads, the lights have to be blinking alternately. not simultaneously. please give me the condition of the power light as well.
  • 526 Answers
The pads do need to be replaced. It is not as simple like the 1280. it does need to be taken into an authorized service center.
we are, and located in southern california.
I have taken the pads out and 95% of the time are all completely soaked. you can do what you did, but you will not get the full life out of a pad.
thanks
Posted on Apr 17, 2009
Epson stylus photo 1400 oil and paper light flashing and on light blinking and the heard does not move
Hi
this can mean number of things, but most likely your 'waste ink' tank is full. You need to either get the printer serviced or reset the ink counter. You can find more information and link to a reset utility here:
http://inkbank.com.au/webcontent22.htm
good luck!
Nov 19, 2014 | Epson Stylus 1400 InkJet Photo Printer
Epson 1440 printer repair
both the paper/ink buttons blinking in red simultaneously means fatal error. Use AP for figure the latest fatal error code. Btw, i have Service manual for 1400. Contact me at aicaxz(at)yahoo(dot)com
Jan 15, 2013 | Epson Stylus 1400 InkJet Photo Printer
Epson R230 2 red light start
epson R230 2 red light start
Printer status Fatal ERROR
LED indicator
power: OFFpaper: FAST BlinkInk: FAST Blink
Carriage Unit cannot move correctlyMotor cannot rotate correctly
Note: CDR (CD/DVD) guide assembly is not close properly will also occurs error or blinking the paper indicator and ink indicator.
For easy to me to understand.Please check the light indicator, either blinking simultaneously?
Jun 20, 2012 | Epson STYLUS R230 InkJet Photo Printer
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
Ink cartridge does not move, and ink and paper red lights blinking
It's must blinking alternately. Need to reset waste ink counter. SSC latest vers. doesn't support for this type. Try to find adjusment program at indoreset.blogspot.com.
Jun 24, 2009 | Epson Stylus 1400 InkJet Photo Printer
The paper and ink lights are blinking simultaneouly epson 1400
It's hard to provide a definitive answer to this without detailed info on the exact flashing light pattern but it's possible you're right in this instance.
If you start up the status monitor you should get more information on this to confirm or indicate any other problems.
If it is the service required issue then you need two resources.
1. the A10_IPR utility
2a. Some kind of external waste ink tank to collect waste ink
OR
2b. To get the printer serviced at an Epson service center
Hope that helps... and if the problem is a "General error" please report back with more information re: symptoms and we'll see what we can do to help further.
Regards,
Martin
May 26, 2009 | Epson Stylus 1400 InkJet Photo Printer
I think this may have something to do with the CDROM printer tray not being closed properly.
Could also be an ink pad issue. Theres a reset utility you can download from epson apparently. Haven't tried it. I know the SCC utility doesn't support the 1400 - although the 1800 software might work??? I'm expecting mine to do the same any day now - although I re-routed the waste pipe into a plastic bottle, so the pads will never actually fill up. Unfortunately, I can't find a way of telling the printer what I've done!!
Mar 17, 2009 | Epson Stylus 1400 InkJet Photo Printer
My printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Mar 10, 2009 | Epson Stylus Photo R200 InkJet Printer
My r230 photo printer epson stylus was sevice required unable to print and see your printer documents
this means the wast pads are full and the printer needs to be reset this is a link for the software needed to reset your ptinter http://www.ssclg.com/epsone.shtml
pla dont forget to rate
Nov 10, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Blinking lights
this means your printer wast pad is full this is now oyu reset your printer but make sure you have put new pads in 1st and dont for get to rate plz
  1. Turn off the printer power and unplug the power cord from the wall. Disconnect the computer interface cable at the back of the printer.
  2. After one minute reattach the power plug to the wall, but don’t reattach the computer cable.
  3. Hold down the ROLL and the PAPER ADVANCE buttons simultaneously.
  4. Turn the printer on. after 2 blinks, all the ink lights come on, then release the buttons being held down.
  5. Press and hold the ROLL button for 10 seconds.
  6. Release the ROLL button and the printer will initialize, which resets the Waste Ink Pad Counter.
  7. Once initialization is complete, turn the printer power off.
  8. Reconnect the interface cable.
  9. Turn the printer on and print a document.
Sep 11, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus  1400 InkJet Photo Printer Logo
438 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
