Question about Toro 15" Electric Trimmer&Edger
I cannot open up the area to repace the replacement spool--------help
How do you replace horizontal spool pin
Hi Phyllis I believe this youtube video will help you, Take care...CHEERS..
https://www.youtube.com/watch?v=abGDVhDlZLs
Mar 17, 2016 | Brother Sewing Machines
What is spooling?
Spooling in computer domain means placing the data for processing in an temporary area where some other program can access it and process it.
Nov 27, 2010 | Dell Computers & Internet
I have a Necchi 537FA sewing machine. It sill sew about 39 stitches and then the thread gets caught in the bobbin area and stope sewing. I've cleaned, changed bobbins, spent time trying to fix the...
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Aug 12, 2010 | Necchi 3537 Mechanical Sewing Machine
I have 11" Toro Trimmer and cannot turn spool counterclockwise to replace line. I am a woman and do not know what to do. Used strap wrench large open end wrench and cannot budge this spool.trimmer is less...
With most trimmers, you may have to push the spool casing inward and then turn. It should unlock fairly easy. You may also want to spray the divider crease on the spool casing with some kind of lubricant like WD-40 or Tri-Flow to facilitate the process of detaching the spool casing from the body. Good luck. I hope this helps.
Jun 29, 2010 | Toro Electric Trimmer
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Borother super galaxie 2100 tension on upper thread is solid will not pull through tread help !
Set the tension control at mid-range and raise the presser foot.
Make sure the thread is not caught on the spool cap or wrapped around the spool pin.
If the problem is not at the spool, and you still cannot get the thread though with the presser foot up - there may be an internal jam.
Open the tension (set at zero), and with the presser foot up, try to pull through a heavier thread - don't tug, you just want to "floss".
If you can't pull the thread though by hand, you will need to take the machine in for service.
If you try to open the enclosed threading area, you may not get everything back as it should be and it will still need to go into the shop.
Mar 29, 2010 | Brother Sewing Machines
Cannot Open Spool Compartment
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Jun 18, 2009 | Toro 15" Electric Trimmer&Edger
Replaceing string spool
if its the newer weedeater brand
All you need to do is grab the bump knob end and pull it straight off no turning
wind your line in the direction the arrows on the spool shows you
to put back insert line or lines into the holes and snap back on
be sure the spool is able to move up and down freely after install
May 26, 2009 | Garden
I just want to change the cartridge
While plugged in open the door on top of the printer it will spool the cartridge to a replacement area where you can remove the cartridge. Get a proper replacement and install and you are on your way. This should help.
Jan 16, 2009 | Dell 924 All-in-One InkJet Printer
How can i repace the line on a black & decker strimmer gl550
Instructions can be found at: https://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gl550_uk.pdf.
If the line keeps getting too long, it's because swivel 14 in diagram 7 was in the wrong position when you inserted the spool - just move it to the ouside position, re-insert the spool and away you go. Frankie.
Apr 20, 2008 | Black & Decker String Trimmer Cordless 12"...
Toro 15" Electric Trimmer&Edger Logo
159 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
