Question about Philips ProScreen 4600 Impact Multimedia Projector
Blue "Shadow" to Left of White Objects
When projecting a dark image, everything looks normal but when white appears on the screen, there is a blue shadow to the left of the object. We just got the projector back from repair and initially it was fine. After about an hour of watching a movie, the shadow appeared. Any suggestions?
Re: Blue "Shadow" to Left of White Objects - Philips ProScreen 4600 Impact Multimedia Projector Multimedia Projectors
I'm in the same boat. Help please!
Posted on Mar 21, 2008
0 characters
3 Points
There is a blue and yellow shadow on a picture i can not achieve the white balance
the issue described is cause by a bad blue lcd panel. if you use a black/dark image, it will be quite evident. unfortunately you'll need to replace the whole prism block assembly (all 3 LCD's) to fix the problem.
May 31, 2011 | Canon LV-7225 LCD Projector
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Multimedia Projectors
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
I,ve got a red spot in the screen i replaced the bulp but stil have the problem
it is most likely a burned polarizing filter. There is a polarizing filter on the blue light channel and another on the red channel. When black, or other dark colours are displayed, the red polarizing filter is supposed to block ALL of the red light being projecter. If the filter is burned, some light slips through and creates a red tinge on the projected image. If the red tinge only appears on dark images, but is absent when the images is completely white, a damaged filter is likely the problem.
Seems its hard to buy them. Best bet is probably buying a broken projector from ebay and stealing the filters out of it.
Oct 04, 2010 | Toshiba TLP 670 Multimedia Projector
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
LP70+ image problems
the colorwheel is dirty and needs cleaning (or replacing), or the light tunnel is starting to collapse (and needs replacing).
Nov 06, 2008 | InFocus LP70+ Multimedia Projector
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Optoma HD72 displays white circles when the picture is dark
Have your projector professionally cleaned. It is dust in the inside optics. You should not attempt unless you are very skilled. if you are going to do this yourself have a lot of compressed air on hand.
Aug 25, 2008 | Optoma HD72 Multimedia Projector
Philips ProScreen 4600 Impact Multimedia Projector Logo
785 people viewed this question
Top Philips Multimedia Projectors Experts
Lawrence Oravetz
Frank Russell
Frank Russell
Are you a Philips Multimedia Projector Expert? Answer questions, earn points and help others
