Question about Techko 6-Sheet Straight-Cut Shredder
No longer cuts through paper
The shredder blades don't seem to cut through anymore - They just leave perforation marks where cuts should be.
Is this shredder done or can the blades be sharpened or serviced somehow?
This is the problem I have the paper no longer cuts all the way. Some parts just seem marked with out cutting what do I do?
Posted on Jul 18, 2009
Does sewing machine oil work as well as shredder oil?
do not use oil in a shredder
the paper becomes contaminated and will not cut
besides that all the oil will be moved by the first sheet of paper shredded
if the paper is not being cut properly get new blades or a new shredder
Oct 01, 2016 | Shredder Office Equipment & Supplies
How do I fix my blades on my shredder?
Try running a layer of aluminum foil between two sheets of paper. See if it shredds, If it does, do it a couple of times, then use shredder oil. It might help to both sharpen the blades, and to keep them sharp longer. It works on cutting blades for scrapbooking cutters and scissors...
Aug 18, 2014 | Shredder Secure Shred Shredder
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Jan 22, 2012 | Office Equipment & Supplies
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
When you put paper in it starts to shred for about 1/4 inch then goes to reverse. No jams that I can see. Can run forward and reverse without paper with no problem. Sensor problem?
No mention of make or model however this holds true for all shredders.... especially if its a "cross-cut" shredder; put some shredder oil onto the cutting shafts where you insert the paper this will help get rid of some of the build-up that occurs due to the shredding process...also give the "eyes" in the middle of the "throat" a clan with a soft cloth( unplug the machine first or it will start to run and take your cloth in.) Occasionaly shrd a sheet of paper with some shredder oil poured directly onto the paper..this will help lubricate the cutting blades. Lastly...only shred up to about 70% of the rated cpacity..this will result in fewer jams an longer machine life.
Oct 19, 2010 | OfficeMax 0M96431 Shredder
Machine won't shred. Does turn on, and goes in
You dont say make or model so...get some shredder oil into the cutting teeth where you insert the paper...especially if its a x-cut shredder..make sure once in a while you shred a piece of paper with some of the oil poured onto the paper for lubrication of the cutting blades.
Mar 04, 2010 | Office Equipment & Supplies
Cutting problem
Pour some shredder oil onto a sheet of paper and shred the sheet of paper...do this a few times to get the oil down into the cutting blades.
Mar 03, 2009 | Royal 1280MX Shredder
My Champion Shredder doesn't cut off after the paper goes through.
Mine now just has the same problem. On mine it was because two of the cutting blades have become bent. It still shreds, but not as fast. You have to turn it on for a split second to see all the blades. You can only see about 1/4 of the blades at a time.
There is nothing you can do. And because my blades are bent it does't dispose of paper properly and also will not turn off automatically now.
Apr 07, 2008 | Office Equipment & Supplies
Royal Shredder
there is a small micro switch in about the middle of the paper slot, make sure it is not jammed, it should move freely and make a small clicking sound with the power off.
Jan 26, 2007 | Fellowes S701CM Shredder
Techko 6-Sheet Straight-Cut Shredder Logo
255 people viewed this question
Top Techko Office Equipment & Supplies Experts
Randy Schumann
Randy Schumann
Anita Nystad
casper muchato
Level 1 Expert
Are you a Techko Office Equipment and Supply Expert? Answer questions, earn points and help others
