Question about Compaq Presario 5000 PC Desktop
Battery light on front panel???
Is there a battery light on the front panel? if so,when lit, does this mean low battery(internal battery)?also a clicking sound is present.
    Sergeant:
    Champion:
  • 293 Answers
Aq clicking sound may be comming from your hard drive, Optical drive or Internal fans.
Posted on Sep 17, 2007
  • Grail Montes
    Grail Montes Sep 17, 2007
    All it has in its front panel is the following...
    Power switch, HDD LED Pins, Power LED and Speaker out.
I have a PKC1086 Vector battery charger and red light is on for the fault alert, what could this possibly mean ?
You didn't say if a battery was connected. The fault light tells you there is a problem with the battery. If no battery is connected and the fault light is lit then there is an internal fault with the charger.
Jan 18, 2016 | Vector Camping, Backpacking & Hiking
Check engine, battery, oil lights are on?
The Check Engine tells you that something is wrong about your ride. Get your ride check for error code and take necessary steps to resolve the issue. Also you can post the error codes so that we can help you to solve the issue. Battery light lit means that your battery needs to be charged or the electrolyte in the battery is low. Also it can be possible that the battery needs replacement. Last the oil light alerts you to change the engine oil. The engine oil prevents the engine components from wearing due to friction and suppresses the heat generation keeping the metal parts in proper working condition.
Jul 18, 2013 | 2011 Hyundai Elantra GLS
What does the ! mark mean on the top of the printer when it is lit up?
The "!" means that the printer requires your attention. It could mean that there is a paper jam, that it's low on ink, that the printer is low on paper, etc.
If there is an error message associated with it and it's now allowing you to print, post it here so someone can identify what the error means.
Jan 21, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
I have the cobra CXT275 they have been on the desktop charger for 5 days. They won't charge over a 1/4 of the way how do I get the maximum charge?
Just went to their site and this is what it said:
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Jan 12, 2011 | Cobra Two Way Radio
The battery light is lit up on the dashboard panel and the word AMP. What does that mean? Also the brake light is on.
It means that your battery isn't getting charged. Either your alternator is bad or the belt is broken or loose.
Nov 12, 2010 | 1988 Nissan Pathfinder
When I plug in my jet 3 ultra the ammeter reads 0. If I turn on the vsi controller the top led display( 3 red, 4 yellow, 3 green) are all lit. I see where that means high battery voltage. The lower led...
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Mar 03, 2010 | Jet 3 Ultra Power Chair
My printer drum light is lit and will not copy. I have put in a new drum and the is still lit and will not copy
Hi
Please follow the bellow instruction…
Open the front panel.
Remove the toner and the drum.
Remove the toner from the drum.
On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them.
Put everything as it was.
Turn on your printer.
Now, the low toner light should be gone and the green light should be on.
Now, you can empty your cartridge.
If the Drum light is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
Open the front cover.
Locate the control panel button under the LED lights on the left side.
Pres the control panel button until all lights are lit, and then release it.
The Drum counter is now reset.
Thanks for contacting fixya.com
Feb 02, 2010 | Sharp AL-1540CS All-In-One Laser Printer
One panel doesn't light immediately. Fills room with gas. Do I need to clean panel?
Light the panel at a very low pressure The panel not lighting is probabably the first pael to get gas and is not having the correct air /fuel ratio to burn. Make sure the igniror is properly positioned. The lit panel can ignite the raw gas expelled by the unlit and create a flash ignition . (explosion) The ceramics a very delicate and I would be reluctantant to advise on clean. You can blow it out with compressed air if available..
Nov 19, 2009 | Vanguard International Infra Red - Medium...
Instrument Panel Codes??
Yes, it's called a lamp fault code.
9 is not familiar to me. Call dealer service department and ask them what code means.
Here are codes for a 94 Aerostar. I don't have 91 Sable. Sorry.
Air Bag Diagnostic Monitor Diagnostic Trouble Code Priority Table Diagnostic Trouble Code Component/Fault Description — No Air Bag Indicator — Inoperative Indicator Circuit or No Battery Positive Voltage to Air Bag Diagnostic Monitor — Continuous Air Bag Indicator — Air Bag Diagnostic Monitor Disconnected or Inoperative 12 Low Battery Voltage 13 Air Bag Module or RH Cowl Side Panel Air Bag Sensor Circuit Shorted to Ground 21 LH Cowl Side Panel Air Bag Sensor Not Mounted to Vehicle Properly 22 LH Cowl Side Panel Air Bag Sensor Circuit Shorted to Battery Voltage 23 LH Cowl Side Panel Air Bag Sensor Circuit Input Feed/Return Circuit Open 24 LH Cowl Side Panel Air Bag Sensor Diagnostic Circuit Open or Low Resistance in Center Air Bag or Front Air Bag 32 Driver Side Air Bag Circuit High Resistance or Open 33 Passenger Side Air Bag Circuit High Resistance or Open 34 Driver Side Air Bag Circuit Low Resistance or Shorted 35 Passenger Side Air Bag Circuit Low Resistance or Shorted 41 Center Radiator and RH Cowl Side Panel Air Bag Sensor Circuits High Resistance or Open 44 RH Cowl Side Panel Air Bag Sensor Not Mounted to Vehicle Properly 45 Center Air Bag Sensor Not Mounted to Vehicle Properly 46 Open Splice Center Air Bag Sensor Ground Monitor 51 Air Bag Diagnostic Monitor Internal Thermal Fuse Blown and Short to Ground No Longer Exists 52 Backup Power Supply Voltage Boost Fault 53 Sensor Circuits Resistance to Ground or Internal Air Bag Diagnostic Monitor Fault — Rapid Continuous Flashing of Air Bag Indicator
Feb 25, 2009 | 1992 Mercury Sable
Honda Accord Headlights
It depends - I'm not positive on the Hondas, but if the fuse is before the switch, it would indicate that the switch can draw power from the battery. However, if the fault is inside the switch, and the contacts internally are screwed up, it could mean that although the switch draws power from the battery, it cannot transfer it out through the proper wires down to the bulbs. It could still be the switch with an internal failure.
Jul 29, 2008 | 1990 Honda Accord
Compaq Presario 5000 PC Desktop Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
