Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My amana fridge wont stop running after l turned it off to clean it
L am from ontario canada my name is mrs laura dale l own a amana 22 upright side by side fridge l was told its 30 years old but l am not sure the model no. is SD22F THE SERIAL NO. IS SZ6100192 now my problem is l turned it off to clean it l didnt unplug it l just turned it off to clean the inside its a frost free fridge but it needed cleaning so after l turned it back on after 4 hours it wont stop running it still freezes and it gets cold on the fridge side but it wont stop running so l was hopeing you tell me what the problem was l had a fellow install a new cold control on the freezer side but it wont help the problem and the fellow said hes not upto date with older fridges so he cant help me so l was hopeing you can give me some advice here l need my fridge and l cant let it keep running like this cause it will burn out the motor so l turned it off l was also hopeing you could tell me where l can get a owners manual for my fridge and a service repair manual for it l dont mind if you find me a place on line where l can down load the manuals onto a disk or print it off l am hopeing you can help with these 2 problems you can contact me at mrs laura dale 61 bell street ingersoll ontario canada n5c2n7 or call 519 485-3219 or email me at [email protected] l am in very urgent need of help here l cant afford a new fridge and l lost all my food l had in my fridge and l been without a fridge for 2 weeks now so l am hopeing you can help me also if you need to pass my information onto someone who can help me l dont mind at all l am so hopeing you can help me thankyou so much for your time and effort and god bless you for this web site it gives me hope that maybe someone can help me many thanks again mrs laura dale
    New Friend:
  • 3 Answers
GE profole side by side fridge: My wife left the door ajar today on freezer side side for about an hour. After I shut the door I noticed that the freezer is constantly running. It has been running for 15 hours now and temp is only at 4 degrees even though I have set it 3 times to zero today. any thoughts?
Posted on Jun 09, 2010
  • 833 Answers
Laura,
You didn't say exactly what the fellow did. The thermostat (cold control??) should deal with both the freezer and refrigerator. Usually, the freezer is regulated and the fridge goes along for the ride. You can usually adjust the vents to make that work out. Your friend may not have properly installed the control or it could be defective. Does the control turn the unit off? If not, the problem is definitely there. I'd have the control checked or replaced again before going on to anything else. I doubt you did anything to hurt the unit by not unplugging it.
You didn't say if the unit is frosting up. 30 year old units can be low on gas. Unfortunately, the type of gas they used back then is only available from a licensed tech.
Posted on Jun 12, 2008
SOURCE:
We moved an Amana Fridge on it's side...how long should we wait before plugging it back in?
Anything with a compressor in it should always be left for 24 hours standing upright then you can plug it in
Mar 26, 2012 | Amana ABB1927DE Bottom Freezer...
I just moved into an apartment that has a side by side amana 22 refrigerator in it. The freezer section is fine everything is frozen and the tempeture is where it should be. The fridge side however, is...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Amana Refrigerators
My freezer side isn't freezing. fridge side seems to be working
If it worked fine to them, look at the heating and cooling C. in the back of the frig. Depending on how you transported it and how many bumbs you hit could of damanged them
Apr 03, 2010 | Amana SXD524VW Side by Side Refrigerator
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
My amana scd23vbw
first do you have any heat from the compressor ? ( back bottom of the fridge) is the evaporator fan running. let me know and I can help..
Sep 05, 2007 | Amana SXD524VW Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
318 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
