Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer - kenmore elite he 4t
Kenmore elite he4t fh is coming on and the water starts to drain and beep
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
I have the code FH going off on my washer I have replaced the water flow meter the entire inner drum and the outer front half of the plastic drum what else can this be it runs fine until it gets to...
Have you checked the Drain Pump Filter? It is located inside the front lower cover and opens counter clockwise. Have plenty of towels on hand when you open it.
Mar 02, 2015 | Kenmore HE4t 3.8 Cu. Ft. King Size...
We have a Kenmore Elite hE4t front loading washer and now it keeps flashing FH code. We have followed all the troubleshooting suggestions - checked water faucets, checked inlet hoses for clogs, no kinks...
check the mesh on your water inlet valve. could be a problem with the valve or the pressure switch.
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
•Verify there is not a siphon problem
•Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
•Check all hoses for possible leaks
•Verify pressure switch operation
•Verify flow meter operation
•Verify CCU operation
Feb 13, 2011 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Error code FH on my AWM, what does it mean?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Jul 12, 2010 | Whirlpool AWM8163 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Getting f an h error code
ok do you have flood stop hoses on your machine. if you do take them off and get a bucket turn the hoses back on and fill the bucket if no water comes out of 1 of the hoses your problem is the hose. the error fh means fill hose.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
