Question about Dryers
Indesit 1570c - it heats but the drum does not turn...
Hello:
I have a dryer Indesit 1570c. It seems to dry but the drum as stopped to turn... Any idea why and how to fix this?
  • ericblog Apr 23, 2009
    hi - thanks.
    I opened the shell and effectivelly, the belt is broken.
    Given the model I have is an Indesit IS70C - ie the European model - do I remove the front or of the back panel to fit the belt?
    Many thanks again!
    Eric
  • 77 Answers
You probably have a broken belt. You have to remove the shell and reroute the belt. You can do it yourself for bout 20 bucks...Good luck. Look in your manual for proper routing of the belt. good luck.
Posted on Apr 18, 2009
  • Jerome Barbin Apr 23, 2009
    All the ones that I have seen, you will have to take the front off. Carefull to not pull the drum off track. Good luck.
My indesit condenser tumble dryerwont start
try door interlock......................cheers
Oct 07, 2016 | Indesit Dryers
How do I change the thermostat on an Indesit IDC85
heater units have 2 or 3 starts ,check they work ..on some hotpoint dryers there is a stat on the front top right just under the timer as wire burns out then no heat ..WARNING TAKE OUT THE PLUG
Sep 16, 2015 | Indesit IDC85S Silver Electric Dryer 8kg,...
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
Indesit IS70C tumble dryer not heating
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 10, 2012 | Indesit IS70C Electric Dryer
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
The dryer stops after about 15+ seconds.
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
May 31, 2010 | Frigidaire AGQ6000ES Gas Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Hi, My Indesit WIDL 102 is faulty. It washes OK, But does not dry at all. I dont think it heats up during the drying time, but the drum does turn round. Is there a thermal reset switch on the inside...
I don't know your dryer model, but I assume it is electric. Electric dryers have a heater coil like a toaster which eventually wears out and doesn't get hot anymore. This is typical and is likely the case especially if your dryer is old or has been used alot. Has the dryer been taking longer and longer to dry before it lost all heat? If so, I bet it is the heater coil.
Feb 28, 2008 | Dryers
Dryers Logo
210 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
