Question about Brother LS-2125 Mechanical Sewing Machine
Janome Embroidery Machine Not Picking Up Bobbin Thread
MB4 always picks up the bobbin when starting a design with a thread that is held in the front coils. After auto thread cutting the thread is held behind the needles, when the machine tries to pick up the bobbin thread with the machine cut thread it often (more than 70% of the time) fails to catch. If you then trim the end with scissors and place back in the front coils it catches and sews fine until the next machine trim. Using Gunold top and bobbin thread, on thin cotton items mainly with medium thickness tearaway. The problem lessens slightly when embroidering thicker materials
SOURCE: needle not picking up bobbin thread
Check the timing.
Posted on Mar 06, 2008
  • 323 Answers
SOURCE: janome mb4
Loud chirping noises indicate a need for lubrication or something is rubbing against your carriage.
sewman7
Posted on May 19, 2008
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
mohammed387
  • 1952 Answers
SOURCE: sewing/embroidery machine janome mc9700 making
Please be more specific with the clicking noise that you are hearing- when does it make that noise, is the bobbin case in or out, where is it coming from,
Posted on Aug 26, 2009
SOURCE: top thread in needle is not picking up bobbin thread- model LS30
Bought a new machine!
Posted on Oct 09, 2009
Embroidery machine bobbin not picking up thread
If you thread is coming out all tangled continue.
I Had this problem and found I had missed one leg of the threading.
I had an experienced seamstress look at our portable and could not get bobbin working. I took thread and redid it ,seems I had missed leg that went down.
she did to now all is well.
Sep 21, 2016 | Sewing Machines
The tension will not stay set . It sews great and then suddenly starts looping!! Like carpet!!and no bobbin shows through on back side at all help!!!
Ewww! Wondering if the tension mechanism has gone haywire.
First, change the needle. (Is the thread still in the correct path or has it "jumped" out of place? If so, try slowing down the machine.) Remove the thread. RAISE the presser foot to insure the thread seats properly in the tension disk and rethread from the beginning. Check that the bobbin is threaded properly. Check the tension setting and retest.
If it is still malfunctioning, it may need service.
Mar 09, 2016 | Janome MB4 Four Needle Embroidery Machine
The machine is locked up. I've tried checking for thread behind the bobbin case, but cannot get the bobbin case to move.
Check your owner's manual troubleshooting section.
Assuming the machine is jammed with thread:
Try removing all the thread, remove the needle, the presser foot and the needleplate (if it is removable). If there is a thread tangle in the bobbin area, try to snip the thread loops and gently pull with tweezers or needlenose pliers. The best thing would be to get the bobbin case out of the machine. Once the bobbin case is out, the thread should be pretty easy to remove.
Oct 22, 2015 | Janome MB4 Four Needle Embroidery Machine
How do I fix my MB4 that has locked after thread caught around bobbin. There must still be hidden thread, how can I fix please, regards Pam
IF THE GEARS ARE PLASTIC, THE LOCKING MAY HAVE CAUSED THE GEARS TO JUMP A TOOTH AND THREW THE TIMING OF THE MACHINE OFF. IT MAY NEED TO BE SERVICED.
Nov 20, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4
I suggest you call a Janome dealer and ask them your question.
Sep 02, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4 why does thread ravel whiles embroidery a project
check for burrs on the needle plate and in the bobbin area
also check for burrs in the threading area,like one of the thread guides
Oct 15, 2013 | Janome Sewing Machines
Model PE-180 not picking up bobbin thread
Possible that the shuttle settings are not correct. remove the bobbin and thread it once again. reset it back on the catch and see if the thread is caught up. follow the directions once again and make sure the thread is freely moving within the bobbin.
Dec 07, 2011 | Brother Sewing Machines
Bobbing thread not picking
Make sure you have threaded the bobbin thread correctly. Also your top thread must be correctly threaded in order to pick up the bobbin thread.
Please let me know if I can help any further.
Best wishes,
Graemevm
May 01, 2009 | Janome 6019QC Mechanical Sewing Machine
Picking up bobbin thread
First easy thing to check, are you using the correct length needle.
If this is not the problem then somehow the needle bar has moved and the the needle depth is to high or the timing is wrong..
Unless you really know what you are doing then I am afraid a sewing machine tech needs to reset the needle depth and subsequently the timing.
Mar 30, 2008 | Singer CE-100 Futura Computerized Sewing...
Machine embroidery
You should always use proper Bobbin Thread for embroidery - not a bobbin wound from regular dressmaking thread. You are right, the special bobbin thread is thinner so that the embroidery thread will be pulled to the underside and you get a nice shiny embroidery on top with no bobbin showing through. Wind yourself 6 or more bobbins at a time of bobbin thread to always have some on hand, or buy the pre-wound L size ones.
All embroidery machines - no matter what brand - recommend using bobbin thread for embroidery. It is readily available at all sewing stores, probably even Spotlight would carry some. If you get stuck for a supply, try overlocker thread.
Dec 04, 2007 | Husqvarna Designer I
Brother LS-2125 Mechanical Sewing Machine Logo
261 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
