Question about Acer Aspire 3680 Laptop
My lcd screen on my acer aspire 3680 loks like a negative
I checked for any loose cables and they were fine so i was wondering do you think i need to replace the lcd screen or the inverter board
  • 230 Answers
You only replace the inverter board when there is no light coming from it. E.g. in a dark room you cannot see any light from the screen. But it sounds very mutch like a cable rather than the whole LCD try and get a cable first it will be LOTS cheaper.
Hope this helps
Posted on May 06, 2009
How to connect an acer 3680 with windows xp to lcd tv
hi khan, its very easy to do this process , you can connect vga card just see this video
immortal4u_0.jpgGood luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Acer Aspire 3680 Laptop
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 08, 2010 | Acer Aspire 3680 Laptop
Can someone help me connect my Acer Aspire 3680?
Your graphics card on that should push that resolution so I would probably lean toward the tv. Try changing the aspect resolution or (zoom button) on the remote to change the way the screen is delivered. As long as the resolution on the laptop is a widescreen resolution and the same for the television. Make sure in your tv settings, that the aspect is set at 16:9.
Jan 12, 2010 | Acer Aspire 3680 PC Notebook
I've tried to on my laptop (acer aspire 3680), but the lcd screen is blank even it already turned on..
check the display on exter monitor through the vga port, if its there then its the fault of the screen, if its not then its the fault of the motherboard of laptop take it to the service centre
Sep 26, 2009 | Acer Aspire 3680 Laptop
Black lcd screen
try to connect it to an external monitor to see if video card is working.
if yes, the the internal card/lcd screen connector may have become loose or your screen is broke.
you will have to remove some parts to check this.
before doing so, get the manual(paper or download) first and look where all the little screws are. if you know someone who can repair PC's he might help out if you let him...
it is a fiddly work but seeing a technician may be cost-intensive.
PLease decide yourself...
Aug 04, 2009 | Acer Aspire 3680 Laptop
Screen stays black when powered on
I replaced my screen on my 5570z, i purchased it off of ebay for 130.00 shipped, but make sure you check out there feedback, and make sure they have a ZERO dead pixel return policy. Some are sneaky and will not let you return it if you have less than 3 dead pixels.
May 17, 2009 | Acer Aspire 3680-2022 PC Notebook
Lcd monitor not working
have the power board checked
Apr 10, 2009 | Acer Aspire 3680 Laptop
Acer aspire 3680 white screen
problably data-cable of LCD has contact problems or is broken. Consult someone with experience in opening the Display. DIY only if experienced, since you can make a $40 repair a $400 repair accidantly ... ;-)
Mar 30, 2009 | Acer Aspire 3680 Laptop
White screen problem while starting Acer Notebook 4710
i think this is ur lcd problem ,u need to replace lcd
Jan 20, 2009 | Acer Aspire 3680 Laptop
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
196 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
