Question about RCA Universal Remote Control
DTA800B1 remote for Sansui COM311ADB
I have programmed the remote for the sansui TV and can change channels, but can not change the volume or turn on and off the TV from the Remote
xCAUSALITYx
  • 210 Answers
SOURCE: RCA RCR311B Remote Control
Download the user manual from here:
http://www.retrevo.com/s/RCA-RCR311B-Universal-Remotes-review-manual/id/402ci569/t/1-2/
Click on the PDF download in the product summary.
Cheers
Posted on Jun 04, 2008
SOURCE: NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Posted on Jun 21, 2008
SOURCE: remote code for a rca plain universal remote
I have a magnavox TV and and rca universal remote how can I program it for my TV
Posted on Oct 18, 2008
  • 17 Answers
SOURCE: find the code for rca remote for sansui t.v.
Try these...0463, 1409, 1935..Good luck
Posted on Nov 11, 2008
  • 144 Answers
SOURCE: Innovage Jumbo Universal Remote Control Codes for the Sansui VCR
Hi there, This should be the PDF file with all the codes you need. Hope this helps!
CBR2009
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
Posted on Jul 24, 2009
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
Sansui to DTV converter box
The model number you provided is for the Sansui tv remote. Are you trying to set up a universal remote that works with your new tv?
Nov 26, 2013 | Audiovox Code Alarm Pt-6c/goh-3bl98 Alarm...
I have a Sansui SLED 2280 that I'd like to use without cable input. How do I switch to regular over the air (no cable) antenna? Thanks
To switch from cable to air or vice versa on most Sansui flat screen tv's including the SLED2280, go into the menu. Select "channel" on the screen. Press "enter" on the remote. Select "auto ch mem" on the screen. Press "enter" on remote. Select "signal type" on screen. Press right arrow button or right volume button on remote to change signal type (cable or air). To program channels into tv, select "automatic search" on screen then press "enter" on remote. Wait for search to finish.
I hope this helps you.
Bobya
Dec 19, 2010 | Sansui Televison & Video
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 25, 2010 | Sansui Televison & Video
Code for my sansui tv/VCR model com311adb does not work anymore codes
Hello, the model for your RCA remote is needed to get the code list for your Sansui combo unit. If you are able to get the number hook up to their website www.rca.com and select the accessories window, follow instructions after that, you'll be able to download the list in pdf file.
Nov 17, 2010 | RCA Universal Remote Control
Manual buttons on set will only accept 3 channels
found solution by holding down both volume buttons at same time which enables on-screen menu allowing to select channel auto program
Dec 07, 2008 | SansuiS3275 TV
New Sansui 27" and remote does not work
On later model Sansui tv's, you can bring up the menu by pushing both volume buttons on the front of the set at the same time. After the menu is on the screen, you can navigate using the channel and volume buttons.
Nov 01, 2008 | Sansui TVM1916 19" TV
Jun 08, 2008 | Big Button TV Universal Remote
Sansui SV 2102 GOT SOME PROBLEM PLEASE HELP TO FIND OUT A SOLUTION OR KINDLY INFORM ABOUT THE SANSUI HELP NO.
on some tv's you can get to the menu by pushing both the channel up and down buttons at the same time.
May 04, 2008 | Sansui COM311AD 13 in. Combo
1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Nov 10, 2007 | SansuiM1315 TV
Televison & Video Logo
248 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
