Question about Sony SLV-D271P DVD Player/VCR
Sony DVDPlayer/V C : SLV-D271P tray stuck shut
VCR operates OK. Clock shows Power OK.
tray will not eject and thus disc is held in tray.
Removing cover does not show any latch or release facility.
gentle push on tray unrewarded.
Please help.
  • 2 more comments
  • cetinch Apr 29, 2009
    With case removed disc mechanism revealed, two tabs are not obvious. Where are they located .
    Also the loader tray is not obvious.
    Removed DVD mechanism from chassis.
    Umplugged two cables. Released drawer,
    mechanism now free to operate.
    Moved drawer in and out.
    Replaced unit, replugged cables.
    No action. It must be in the electronics.
    Now power to the drive motor.
    Perhaps a failure of a drive device on the board.
    Can't complain about the service.
    Problem not mechanical.
    Thanks,
    Carl
    I am confident there is no electrical power going to the motors.
    The mechanical parts operate manually all right.
    All this was done with the unit unplugged from 110 so there was no electrical danger.
    The three motors are readily visible.
    I am afraid the problem is electronic.
    Thanks anyway.
    Carl
    Thanks for the help.
    Repair failed.
    Problem not with the expert.
    Cooperation good
    I'll not unhappy with the help.
    The diagram did help.
    Thanks to all.
    Carl
    PS. I would recommend your service.
  • Sony Master
  • 3,866 Answers
If you trying to get this to eject you going to need to carefully open this up to access the manual release, Aslo if it does not want to push back in the tray retractor motor is stuck or broken check these things if you feel you can open it up without harming other units around the problem.
There is a couple motors in this unit that will need to be checked but please unplug the unit before trying these solutions, please rate the soluton accordenly- thanks
Rulds2008
GURU
Posted on Apr 29, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Apr 29, 2009
    As reading you other part of you comment yeah the drive device logic board may have failed you as well, but please rule out the motor's first, Thanks
  • Grand Canyon Tech
    If the signal is not getting to the motors and you happy with that? That is fine I am try to rule out a solution here for you and take out the quesswork, would you please rate the solution though please?
    Thank You
  • 10,594 Answers
You can eject disc manually by pushing emergency eject lever by screw driver at side of cd drive mechanism and tray will come out slightly then pull it all the way, as shown in below image.
Hit "add a comment" button for further query / info.
Thanks.
Sony DVDPlayer/V C : SLV-D271P tray stuck shut - 5154718.jpg
  • Shahid Electronics
    Shahid Electronics Apr 29, 2009
    Thanks,
    Carl
    I told you to hit "add a comment" button to reply to move forward but you reposted your problem and I lost opportunity to assist you any more in electronic problem of this unit.
    Good luck.
    Brigadier General:
  • 3,917 Answers
1 Step Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2 Step2Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place. 3 Step3Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases. 4 Step4Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet. 5 Step5Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD playersSony DVDPlayer/V C : SLV-D271P tray stuck shut - mag-glass_10x10.gif will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center. 6 Step6Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc. Thanks
Sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
May 14, 2012 | Sony SLV-D350P DVD Player/VCR
Sony SLV-D370P DVD Player / VCR Combo I get the following error -This disc cannot be played. Please check the desk DVD_ERRLOG5 00050106000000000006 01010c00000300020024 Any suggestions....
everyone who bought a sony DVDplayer/video cassette recorder SLV-D370P should contact sony and complain. Then, we should all sue sony for everything they got!!! I'll never waste my money on sony again.
Jul 03, 2009 | Sony SLV-D370P DVD Player/VCR
Sony slv-960 VCR cassette stuck inside
As your "free service" is not free I solved the problem by throwing the item into the trash.
Jun 25, 2009 | Sony SLV-675HF VCR
Sony dvd/vcr (model slvd271p). dvd disc tray won't open.
get a refund. This fault is a can of worms mate. A road you do not want to go down
Dec 24, 2008 | Sony SLV-D271P DVD Player/VCR
VCR Tape is stuck in Sony Video Recorder, model SLV-620HF.
In vcr you mean? try unpluging the electric cord for 1 hour
then plug it back up. it just might eject it out. mine did.
Nov 11, 2007 | Sony SLV-640HF VHS VCR
Sony SLV-D271P DVD Player/VCR Logo
574 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
