Question about Hitachi 60UX58K 61 in. Rear Projection Television
Won't power up
Nothing looks burnt on the boards, no funny smell. TV worked great this morning. Went to turn it on tonight, nothing, not even a flicker. Found that by unplugging it for a minute, then plugging it back in, it would start to power up, the led's would light up as far as Diode D946, and then the TV would simply shut off. Any help would be really appreciated. Scott
  • winterbrooke Nov 18, 2007
    I have the same problem what can or do we do??
  • Hitachi Master
  • 3,459 Answers
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Dec 20, 2008
SOURCE:
Dynex tv wont come on, the red light is on. Model
Does the red light come on and go off as you push the power button?
Dec 05, 2017 | Televison & Video
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
I turned off my Polaroid FLM-323B this morning when I went to work, came home tonight, NO VOLUME. the pic is great, but no matter what I try, I can not get any volume. I have unplugged it, changed...
I had the same thing happen to me a time or two and after extensive troubleshooting I found a simple solution which will hopefully work for you as well- at least in the short run:
Unplug the TV for 30 seconds or so. Then plug it in and try again.
Unfortunately you're probably going to eventually run into the same problem that I'm having now- the TV won't turn on or even light the indicator. I'm guessing it's a short somewhere that caused both issues which slowly escalated. I'm going to be working on that soon to see if I can just replace a fuse.
May 24, 2011 | Polaroid FLM-3232 Television
It won't start. Could it be the lamp?
I have a 36" Panasonic TV (manufactured in 2004) that suddenly stopped working. It was working fine up until I turned it off one evening before going to bed. The next morning, when I went to turn it on, NOTHING. No power indicator light, NOTHING. I'm a big "do-it-yourselfer", so I took off the back cover of the TV case and discovered that it was just a burnt-out fuse. It is a small "snap-in" glass fuse that should be mounted to a circuit board near the area where the main power chord enters the back of the TV. I found the replacement fuses at Radio Shack. The fuse came in a package of 4, for $2.99. Cheap fix and works great! The biggest problem I had with the fix is that the TV weighs 386 lbs., so I had to get help lifting it out and back into the entertainment center.
BK
Dec 08, 2010 | Panasonic Televison & Video
I just bought a DOA VC RV... looks great, plugged it in, the power light came on, the screen displayed the JVC Digital Television Logo in clearly, it then goes away and nothing works, is there a test i can...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc. These two board are the most failed parts in LCD TV.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=JVC+LT-32E488+
Please post back what you find.
Dec 17, 2009 | JVC LT-32E488 32 in. LCD Television
I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Aug 13, 2009 | Televison & Video
Yes the light is under the power cord. I unpluged and waited for the light to go away. I give it about 30 min then pluged it back in. that did not work. every thing else on the same power strip works. It...
Sounds like a power supply. Look for fuses on the motherboard that could be blown. Also, you may smell a distinct smell of burnt electronic devices when you smell near PS. Good indication it is fried.
Jun 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Sanyo T.V.
take the back off the tv and where the power cord hooks into the tv check the fuse there on the board if this isnt blown then you are probably looking at a power supply problem look at the board for anything that looks black and burnt or dark brown spots on the board. this will tell you where the problem is if it has any. but it just might be the fuse.
Dec 22, 2007 | Sanyo DS31590 31" TV
Toshiba theaterview tz50v51
my guess would be flyback however your lucky you might be able to see a burnt spot on the board giving you a better clue.
Nov 25, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
141 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
