Question about Locks & Locksmithing
Let our Experts solve your ''the key turns the deadbolt when unlock (when door is open, but it will not lock the when the door is closed'' Problem
  • 62 Answers
It sounds like the door or lock is out of adjustment with the door jamb, with door open and deadbolt in the locked position close door easly against face plate with pencil make top and bottom where bolt align then look to see if it line up with hole in jamb if i doesnt then door will need to be adjusted
Posted on Apr 18, 2009
How do I fix a Schlage deadbolt. B60 series will not unlock from the inside unless the key is inserted from the outside
With the door open, remove the interior trim (thumb turn) from the door, and using the key, turn the deadbolt to the locked position. Now re-install the thumb turn, in the locked position, and with the key removed see if you are able to unlock the deadbolt. I suspect that the tailpiece (part that sticks out of the lock cylinder and into the thumb turn) is not in the correct position.
May 02, 2014 | Schlage B60 Series Double SecureKey 5-pin...
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.)
The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
Jan 05, 2014 | Kwikset Locks & Locksmithing
When i try to lock or open with key pad it will make the sound like its closing but the bolt does not move. can only lock and open with key.
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Jan 30, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Tubular design deadbolt stuck in lock position. Door cannot open.
if you remove the screw from the deadbolt and remove the keyed parts you can see the plunger assembly. you can use a flat head screw driver and turn the plunger in. it will unlock the door and you will be able to replace the deadbolt
Sep 13, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I have deadbolt segal lock that was working for 2 months. suddenly today i can't lock the door from the inside. locking works from the outside. when i lock it from the outside i can unlock it from the...
Sounds like the tumbling mechanism for the handle may be off......check to make sure that the screws are tight that lock the front and back of the deadbolt together. Make sure that the door is fully closed and check to see where the deadbolt is hitting the striker. It mat be as simple as the door and frame have expanded a bit and the door is not fully seated when you close the door from the inside. See if these help if not please contact me as I wish to find a solution to your problem.
Thx
Deathstalker
Aug 21, 2009 | Locks & Locksmithing
My key is stuck in my Kwikset deadbolt door lock
spray a little bit of oil where you insert the key turn it a couple of time to make sure it is lubricated then turn to correct location to pull out key hold cylinder in with finger key should pull out
Mar 26, 2009 | Kwikset Locks & Locksmithing
New deadbolt mechanism very hard to turn.
The deadbolt itself is binding in the door or the door jamb
you will ned to take the pressure ofF the turning mechanism by either readjusting the strike plate(area where deadbolt goes into door jamb(wall side) OR MECHANISM IN THE DOOR
FIX
First determine if the problem in the door or when the door is closed and is binding into the wall side
FIX FOR BIND WHEN DOOR IS IN CLOSED POSITION
If it binds only when door is closed you will need to adjust the strike plate up or down at the door jamb which is easy to fix
1 open door and turn lock in locked position close door up against the door jamb and mark with a pencil where bolt hits jamb
2 open door extend the marks to see where it lines up in relation to the strike plate remove strike plate and move so that the opening of strike plate is between two pencil lines
3 insert some wooden match sticks in old scres holes( jamb them in with head of hammer
4 screw strike plate in positon
5 close door and check lock
Note:
You may have to use a chisel , flat bladed screw driver or kinife to cut some of th soe out to allow bolt to slide into jamb (if it bareley drags you can take a metal file and file it also pt some wd 40 on bolt
FIX FOR PROBLEM WITH MOVEMENT IN DOOR
open the door from the inside turn the bolt in lock and unlock position if it moves hard you will need to take a phillips head screw driver and remove the plate that covers the bolt( on the side of the door where bolt slides out of door)
After you remove the plate turn the lock in lock/ unlock position
if it is still tight loosten the two screws at the deadbolt from the inside of the door do not remove completely
bolt should not be in a bind and should move freely
If it is tight at this point you wil ned to remove the assembly(continue taking 2 screws out) once you have the assembly out you will need to pull the bolt ot of the side of the door
if the dead bolt is real tight you will need to enlarge the hole it goes in by using a round rasp or file
and check the ock manually and with a key
Good luck
Jan 05, 2009 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
122 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
