Question about Linksys Wireless-G WRT54G Router
INTERNET LIGHT IS RED
I was trying to put the option in my linksys router so that outsiders cannot connect to my network. Doing so I presssed the reset button and maybe the earlier settings got deleted and now I'm not able to connect to internet thru my router, my internet is working through direct line. how to solve this problem. Please help. my id is artichhabra@hotmail.com.
  • 298 Answers
If you reset your modem then you did infact erase all the settings that were entered in previously to make it work with your ISP or setup. You will need to reconfigure the router or have someone do it for you that can physically be at your machine.
Posted on Apr 17, 2009
Set up linksy 2.4 ghz
Instructions
    • 1Shut down any devices you wish to incorporate into your network, including computersicon1.png and cable or DSL modems.
    • 2Connect one end of an Ethernet cable to any of the numbered ports on the rear of the routericon1.png. Connect the remaining end to the Ethernet port on your computer. Connect a second Ethernet cable to the port on the router labeled "Internet." Connect the other end of the cable to your high-speed modem.
    • Sponsored Links
    • 3Power on your high-speed modem. Plug the router's power supply into any available electrical outlet and connect the power supply to the appropriate port on the rear of your router. Examine the LCD lights located on the front of your router. Wait for the LCD light labeled "Diag" to stop displaying a bright red light, and then turn on your computer.
    • 4Open the network management control panel for your operating system. In Windows, open the "Start" menu, select "Control Panel" and double-click on the "Network Connections" icon; in OS X, open the "Apple" menu, select "System Preference" and click on the icon labeled "Network."
    • 5Configure your network settings. In Windows, double-click on the icon labeled "Local Area Connection," click on the button labeled "Properties," click on the option labeled "Internet Protocol (TCP/IP)," select the option labeled "Obtain an IP address automatically" and click "OK" twice. In OS X, select "Using DHCP" from the pull-down menu labeled "Configure IPv4." Repeat this procedure with any other computers you wish to connect to the router.
    • 6Open your Web browser and enter "192.168.1.1" in the address field. When prompted, leave the "User Name" field blank and enter "admin" in the "Password" field. Locate the wireless mode menu and select the appropriate option, based on the types of devices you wish to connect to your network (if uncertain, select "Mixed"). Choose a unique SSID name and enter it in the appropriate field. Click "Apply."
    • 7Click on the button labeled "Enable" next to the option labeled "WEP." Click on the button labeled "Edit WEP Settings" and enter your desired security information. Make a note of these settings, then click "Apply."
    • 8Restart your computer. For those computers you wish to connect wirelessly, open their network configuration screens and enter the security information in the appropriate fields. Setup is now complete.
Read more: How to Set Up a Linksys WRT54G Wireless G Router ' eHow.com http://www.ehow.com/how_5133173_set-linksys-wrt54g-wireless-router.html#ixzz2CVg8SB27
Nov 17, 2012 | Linksys Wireless-G WRT54G Router
My Samsung TV connects to the internet when I plug it directly into my D-Link DSL modem. But when I run it through a Linksys WRT54G router (using a wired connection) the TV can't "see" the internet. I've...
have you tryed bridge mode on the modem
which device is doing the routing dhcp only one can do the dhcp
is the internet light lit on the router, the router is set for ppoe for dsl
try turning off dchp on the router let the modem handle
Jul 06, 2017 | Linksys Wireless-G WRT54G Router
New Laptop won't connect to newly created network.
Is the wireless turn on on the computer?Can you view wireless networks.Did you set up security on this router?did you log in the router and set it up?You might want to look at the wireless setup in the router.Try using the install cd that came with the router.
Good luck
Nov 19, 2009 | Linksys WRT160N Wireless Router
Cannot connect wirelessly
You need to setup cisco page, with your ISP. Your setup name and password must be same for all computers. All computers for this installation must connected by wire at the beginning. And make sure you enable the wireless options on Linksys page. READ HELP form Linksys main page.
Aug 12, 2009 | Linksys Wireless-G WRT54G Router
Can't connect to wireless
Hi, the first thing i would recommend is going to your linksys router and try turning it off for approximately 10 seconds then restoring it. Routers need refreshing at leasy on a monthly basis and tend to lose connection. Step 2: if that does not work try the following. first click start, then go to control panel, then click network and double click network and internet connections. then click on network connections and right click on the network connection you use and click repair option. The repair option will fix your connection most likely.
Jun 08, 2009 | Linksys Wireless-G WRT54G Router
Linksys router's internet led always red
if your not able to connect then id try rebooting it all start with the modem then the router and your pc see if that helps and if nothing works it very well could be the modem
May 20, 2009 | Linksys WAG200G Router
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
How do I connect a Linksys WVC54GCA camera to the router?
the camera and the router need to be on the same "subnet" if you don't understand the "subnet" please e-mail me at frcs68@hotmail.com.
the other things is that you can only use the camera "within your network". you can't see the camera from outside. like Starbucks, at work, or by use of any internet browser. etc.
I am assuming you want to able to see the camera using the web browser.
in order for you to see the camera from outside of your network, you have to enable a port on the router. (don't know if you have to enable a port on the Modem). which open your network for attack by outsider. In another words, anybody with wireless laptop can find your network and tap in to it and use it for what ever they want.
Oct 31, 2008 | Zyxel ZyAIR G-4100 Wireless Router...
LINKSYS WIRELESS - G WAG54GS
Diana, The router has lost its IP address from the ADSL gateway. Unplug the router from the wall for about a minute or two. Plug it back in..? If that doesn't work you need to login to your router and check the settings. or(there is a small reset button on the back of the router. Hold it in for 10 seconds the router will reset.) http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper If possible turn your computers off while resetting the connection. Some inter Microsoft networks will issue its own IP if it doesn't detect one. Good Luck, Tim
Feb 07, 2007 | Linksys Wireless-G WRTP54G Router
How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys Wireless-G WRT54G Router Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
