Question about Samsung HT-DB390 System
Sound problems This system had the same problem some others were having. It would say protection when powered on and then turn off. There was a fix on here for a reset that got rid of that problem but now I don't get any sound just hiss from the speakers. The DVD still plays but the audio does not. I get a lot of static and when you do a speaker test the tones are just static and they dont come from the speakers they should.
    Novelist:
    Scholar:
  • 149 Answers
First, wiggle the input for the speakers around to make the connection is in place. That can sometimes give you a hiss if the signal isnt connecting. If that doesnt work, then check the DVD eye to make sure its working properly. Try to unplug it, then plug it back into the wall in order to fix the issues. If the product is still under warranty contact the manufacturer immediately to discuss this. If not, check to see if the manufacturer has had any recalls on parts or have firmware upgrades. that can sometimes resolve those issues. Good luck, keep us posted!
Posted on Sep 17, 2007
SOURCE:
I have a MTS surround sound system and when i put the volume up the woofer turns off. whats wrong with it? and how can i fix that
Seems you are over driving the unit and causing it to overheat and the protective circuits are kicking in. U need a more powerful system to play at the volumes you want.
Aug 26, 2017 | Audio Players & Recorders
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
I am experiencing distortion on my bose lefestyle 38. I only notice when playing dvd's or hd channels that have 5.1 sound. Any ideas?
Completely power down the system, by first turning it off, then removing the power cord from the wall socket. Wait a minute or two. Then, reconnect the power, and turn on the system. This should clear up the problem.
For future reference, it is good to use a top-quality surge suppressor, at the power source, to protect your Bose Lifestyle sound system.
Dec 29, 2009 | Bose Lifestyle 35 System - black Theater...
MY Fender Passport P250 went into protect mode. I changed the FUSE at the power supply with a new fuse. Still it is in Protect mode. How to fix this
This needs to go to the repair shop. The protect mode is turned on when either the power supply has a problem or one or both power amplifiers have a problem. These are often blown components.
These units are HARD to work on. To open you have to first remove then front panel before you can remove the back panel that has the power supply and power amps/heat sinks.
Compare repairs of these units to working under an automobile dashboard!
Hint: On startup, use a series 150 wat lamp to limit current while repairing. SInce these use a switching supply operating off the input line, use an isolation transformer for personal safety.
Oct 04, 2009 | Fender Passport Deluxe 500watt Sound...
Everytime i turn on the stereo it shuts off an says protect
When sound system shows Protect that means it got problem in amplifier section and protection circuit is activated that shuts down system in safety. Qualified tech will fix it.
Jul 31, 2009 | JVC HX-C6 Shelf System
"Protect" and "Push Power"
i have a sony component push power protect, i have already replace IC but still protect push power
May 02, 2009 | Sony Audio Players & Recorders
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Sep 27, 2008 | JVC HX-C6 Shelf System
Power supply of HP server tc2110
Hi there ,
go to the pc and shutdown then check the RAM then fix it again generally when the M/c gets older it deposits a lot of dust
Bye for now
Jul 12, 2008 | HP Server Tc2110
Power On Displays Flashing "Protected"
The audio amplifier IC´s are on short circuit.
Jun 15, 2008 | Sony STR-DE535 Receiver
Protect and Push power
A sign flashed across the screen "Protect and "Push power" Please what does this mean? and what do i need to do to fix it?
Regards
Fabio Catarcione
Dec 22, 2006 | Sony DHC-MDX10 Shelf System
Samsung HT-DB390 System Logo
205 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
