Question about Car Audio & Video
I am trying to put a delco radio in a 93 ford thunderbird but the harness is striped to just wires i need the color coding on them so it will work
    Genius:
  • 1,605 Answers
The red usually is the power input, black is the ground.
attach a ground wire to a 1.5v battery and tap the + of the battery to any of the stripper, when you hear the tap sound from the speaker,that will tell you what wire to which speaker.
if you have any wire left over, try for power ant.
Posted on Apr 17, 2009
Color codes for stereo
They make kits just for this. Just plugs into the existing harness and then you run you wires to the wires from that harness, some may even have matching plugs that go directly to the Head units wire harness plug. I did My Mustang by cutting into the wire Harness and simply used a multimeter to check for battery, memory 12 volts and running light or dash board Illumination wires then you can test the wires coming out from the stock radio to see which are right, left , front, rear, antenna out, etc..
I just labeled them with magic marker on some masking tape with what they were before I cut off the harness permanently.
Jan 23, 2014 | 1999 Ford Contour
Cant find a harness to plug into the back of a Dual XD250 RADIO.
You won't ever. They make a universal harness. You should have a wire harness for your new radio only that was included with the radio. It should plug into the new radio and the other end will just be wires. Then you will need to go to a parts store, ( AutoZone, Oreilly's, Advance Auto, Etc) and but a radio wire harness for your truck. It will have a connector or two that plug into the harness that plugs into the back of your stock radio and the other end will be just wires. you will then connect the two harnesses together by matching wire color. ( EG: Purple to Purple, Gray with black stripe to Gray with black stripe, etc)
Dec 11, 2013 | Car Audio & Video
I need awireing diagram for a premiun sound (jbl) stereo with cd player for a 93 thunderbird
you should get a wiring harness to save you the trouble, however i just put in a kenwood in a 1997 thunderbird, if you cut the black wiring cover all the speaker wires are wrapped together and the other wires will be 12v constant acc, ground, etc. here is a diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire : Orange/Green
Left Front Speaker Negative Wire : Black/White
Right Front Speaker Positive Wire : White/Green
Right Front Speaker Negative Wire : Black/White
Car Audio Rear Speakers Size: 5x 7 speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire : Pink/Green
Left Rear Speaker Negative Wire : Pink/Blue
Right Rear Speaker Positive Wire : Pink/Blue
Right Rear Speaker Negative Wire : Green/Orange
Feb 03, 2013 | 1993 Ford Thunderbird
All i want to know is what each wire does and for how i would install a radio.
when installing an aftermarket radio, you will have a wiring harness with the new radio. you will have to buy seperate an adapter harness for the vehicle you are putting the new radio in. these wires are usually labled. Just match the colors with colors. watch for solid colors and the wires with stripes on them. The solid ones are positive and the one with stripes are grounds. Its pretty self explanitory once you start doing it
Sep 14, 2010 | 1986 Ford F 250
Trying to hook up non factory radio into 1987 Ford Thunderbird do not know how to match up wiring
Hello ger1eye,
You can get the wiring color code here at Modified Life. Then simply match up the functions from your Pioneer.
If you do not want to cut or tap into the the vehicle wiring harness, you should probably consider purchasing a vehicle specific wiring adapter made by Metra or Scosche. Most of the online car audio dealers such as Crutchfield and SonicElectronix sell them for $10-20.
Hope this helps.
Apr 28, 2009 | Car Audio & Video
Radio wiring
Get an aftermarket wiring harness from Advance Auto PArts and ****-Connect them.. or Take it to a radio shop..
Mar 17, 2009 | 1991 Ford Thunderbird
Installing new radio
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Dec 26, 2008 | 1990 Honda Accord
Chrysler Part No. P56038933AB Radio Wire Color code
1982 to 2001 wiring harness color code Chrysler.
12V constant pink or pink/white stripe
12V accessory red/white stripe
Antenna/Amp turn on white
12V Illumination black/yellow stripe
Left front + dark green
Left front - brown/red stripe
Right front + purple
Right front - blue/red stripe
Left rear + brown/blue stripe
Left rear - brown/yellow stripe
Right rear + blue/ orange stripe
Right rear - blue/white stripe
there is no ground wire in the harness, the metal braided strap is the ground.
use a ring terminal,speed clip, and screw to attach the ground wire from new radio
when replacing infinity radios and speakers, there are 4 wires instead of 2 at the speaker plug. the large gauge blue and black wires are the power supply for the amp, the other 2 are signal wires from the deck and will match up to the wire color codes above. simply cap off the power and ground and use the other 2 for speaker leads.
One thing i hate to see is someone who just hacks off the plugs behind the radio because they are too cheap/lazy/dumb to buy a wire harness adapter for the nice new aftermarket deck they just bought. ive seen everything from masking tape to house wire nuts used to connect wires, and they never last.
there is only 1 reliable permanent way to connect wires together - SOLDER AND SHRINK WRAP!!! whether you're connecting wiring for a radio, fog lights,repairing a cut wire, etc solder those wires, you'll be glad you did when you never have a problem with that circuit again.
This is a listing for part #'s for dash kits wire harness adapters
all part numbers are metra unless otherwise noted
dash kit 99-6700, 99-6701 and 99-6500 will work for most cars
wire harness adapter 70-1817
reverse harness( to replace factory plug that have been cut off) 71-1817
speaker adapter plugs 72-6510, non amped 72-6513 when equiped w infinity system and bypassing fact amps
no antenna adapters are required until you hit 2002 model year.
beginning in 2005 chrysler switched to a high speed LAN system in all its cars and trucks. there is no longer a switched ignition lead in the harness.
Good Luck
Leadispenser
Aug 25, 2008 | Kenwood KDC-MP235 CD Player
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
