I cant move the heavy blocks of black buccner
  • Mike  Petrowsky
    Mike Petrowsky May 11, 2010
    Can you be a little more specific?
    Problem Solver:
  • 6 Answers
While ur playing black buccaner to move the blocks u need to hold the button shift and try to move them they had to move.while i am playing they moved While i hold shift key.
Posted on Jul 31, 2009
Opel corsa 1.4i heavy on fuel and producing rich black smoke
You must have a fault code test run first, that is the start point on all modern systems of engine control.
Jul 07, 2016 | 2005 Opel Corsa 1.4
How do I drain the water out of the machine to prepare it for moving?
Is it a washing machine or a dryer?
Dryers are usually not heavy from water.
If it is a condenser type of dryer the water collector can be removed.
If the washing machine has completely finished its last wash, there should not be much water left.
Washing machines are usually heavy because they have a concrete stabilizer block mounted on top of the drum cage.
May 11, 2014 | Dryers
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
Heavy black line on sent faxes
You have a defective Scanner Block. EXPENSIVE
Apr 20, 2010 | Brother IntelliFAX 4100 Laser Fax
Cant locate the thermostat on 94 jetta 2.0
Nonsense.
The thermostat on the 2.0 l ABA motor is located in a black plastic housing which resides on the UNDERSIDE of the motor, on the passenger side. It is normally hidden by the power steering pump, which must be moved out of the way in order to access the thermostat. Don't lose the o-ring!
Feb 28, 2010 | 1994 Volkswagen Jetta
Hi i cant move my torque setting its just stuck on hammer and drill,speed ie 1 to 3 is okay but i cant get it to move to 1 to 21 is this a common problem thanks
You have an internal issue in the housing. Sometimes they will move while slowly operating the drill. If that does not work, the housing has to come apart, more specifically the head.
Jan 16, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I am trying to remove the head and cant get it to budge. it has the 4.0 litre
If you have all the head bolts removed you should have fourteen of them..
Make sure that any brackets at the front that attach to both head and block have been removed. The head is pretty heavy (if I remember correctly something like 70lbs so it may not move easily.) If exhaust and intake are still attached, even heavier.
Jan 05, 2010 | 1993 Jeep Grand Cherokee
I have a type 2,#92 heavy duty sander,length of right angle sander is 14".. approx 35 years old............need brushes. whee can I find these please...
First try Black & Decker Serves Department. At some Hardware stores (ACE, True Value, etc)they stock brushes in the back room.
Jun 12, 2009 | Black & Decker 4.3A 6" Heavy Duty Right...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
