Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power on and shutdown problems
I have a D52W20 (D5W20YX1, chassis ATC221) that I received from a friend as a project TV, and that I would like to get working. I am reasonably experienced in electrical engineering in many aspects, since it is both a hobby and something I do a fair bit in my work (I do electrophysiology and neuroscience research)... so I am very comfortable working inside the set and am aware of the safety issues involved. I'm not trained in TV repair, so any technical information and advice you folks can give me would be greatly appreciated. Most of the time, it will not start. After pressing the power button there is an immmediate faint click, and the green power LED will come on for about 10 seconds before turning off. The set will do this 3-5x, then require a minute or a few minutes before power-on can be attempted again. Sometimes (maybe 1 in 15 tries) the power light will stay on for longer - more like 30sec to 1min before turning off. Very infrequently - say 1 in 200 tries - there is an audible "thwip" and the crackle of HV electronics being energized, and the set will turn on! Sometimes it will stay on for quite some time, and when I first picked it up I managed to keep it on for a day at a time with no ill effects, though now if it turns on it will most likely shut down after a few minutes of use. Because the problem is intermittent and multi-symptomatic, I'm temped to start by cleaning/reseating all interboard connectors and reflow some solder joints at suspect locations. Snakehead, you seem to have given some advice to this end in other posts - can you elaborate on what solder points and/or connectors tend to be prone to failurs? Thanks in advance for any help you all can offer. I would also appreciate recommendations about service manuals - am I best off buying the official thomson one?
  • pyrilium Sep 17, 2007
    The problem does and has numerous times persisted across long power-off cycles. I'm specifically interested in regions where this chassis is known to have had problems vefore - particularly since someone mentioned the need to reflow solder joints before (a problem I've struggled with myself in the past). I think the flyback and horizontal output blocks are a good place to start?
    I'm also interested in good sources for service information and shematics outside the official thomson resources. I'd like to repost this for a couple of further opinions, if this doesn't reflect negatively on the respondants.
  • pyrilium Sep 18, 2007
    Also worth noting, the problem seems to have evolved from the TV generally being able to stay on indefinitely after it "caught" that one time in 100 to now, where it pretty consistently shuts down after a few minutes (2-10) of operation in the following manner:
    The picture quickly collapses/shuts down to black with concurrent loss of audio output while the green power light will stay on for a minute or so, after which the green power light turns off and the set won't respond to power-on requests (no green light) for a further minute or two.
    Master:
    Sergeant:
  • 461 Answers
Try to reset the unit.. turn off and take the power supply cord off the socket for 30 min. Turn it on again.. Next, try to check the power supply circuit for any capacitor problem.
Posted on Sep 17, 2007
SOURCE:
D52W20 chassis ATC221 picture is fuzzy,blurred,unreadable.I do have a"convergence" option on the menu.have not done anything to the fuse fl231 yet.Will it help if replaced?The convergence does...
Yes - that may help if its done correctly...Sites like www.TvRepairKits.com have the parts and also parts with instructions to do it right the first time.
Aug 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Our 52 inch RCA tv Model #D52W20 will not come on when we power it on. If we keep hitting the on button it will eventually come on. When it first started it would come on in about 10 min now it takes...
Replace the CP150, CP120 and CP114 Capacitors. You can get the RCA repair kit called the ATC221 CP150, CP114 and CP120 repair kit from www.tvrepairworld.com which contains the caps for the ATC221 and ITC222 versions of your model along with the CD with repair instructions.
Apr 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 52"
Yes the ATC221 uses the 259296 flyback. If audio works and the on screen menu also comes up but no video its most likely a vertical deflection issue. I would check the vertical IC for signs of bad solder.
Mar 29, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
After 10 minutes power shouts off
small signal board is the most likliest cause. That a common problem with the ATC221 and ITC222 that model used both different chassis designs. www.tvrepairworld.com has replacement boards available.
Feb 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 ATC221 TV Schematics/Service Manual
go to www.tvrepairworld.com they can assist you and they have all the components for the RCA ATC and ITC series televisions and very knowledgable staff for RCA problems based on symptoms.
Apr 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" D52W20 ATC221 TV Problem
The FBT is dead.The buzzing sound mean there no high voltage is come to the CRT(tv tube).No burning,marks on the FBT doesn't mean it not dead.I change parts all the time with out burn marks on them.Trust me i replaced dozen of the FBT before.It make buzzing noise it dead.
Mar 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have an RCA D40W135D with ATC221. Will not come
Sounds like the HV splitter, Very common problem with that chassis
Nov 22, 2009 | RCA D52W19 52" Rear Projection Television
CONVERGENCE WILL NOT ADJUST ON SIDES
First you need to read the supply voltages to the STK's. Black things, size of 2 match books on a big heatsink. Sounds like your supply voltage is low, could be a bad STICK STK. usyually stk 130-20 or 150, etc..
Mar 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No power
Check the ribbon cable connections between the boards to insure they are correctly seated as a 19 code usually means
Chassis detection, which means its not detecting a valid chassis usally the ribbon connections are the cause of that.
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
