Question about Sterling Home
Total flushing / it is sterling 1.6cpf/6.0lpf I have added about 2in. to the overflow pipe to increase amount of water for better flush to no avail. the problem seems to be ,the last part of the flush to be a swirling action instead of sucking action. before i buy a new tiolet maybe i could get an answer thank you
  • 1 more comment
  • jjmumford Apr 18, 2009
    it seems to me the torbeck valve is involved with filling not flushing. my first thought is the design flaw or maybe venting. this is a new house. what do you think
    as to solution #2 in my initial contact i said raised the overflow pipe 2in to alow me to bend the float the highest. so that has been tried
  • jjmumford Apr 21, 2009
    hi again, first what do you mean the trouble is in the toilet. I replaced the fill valves as a last resort. the original(master mark iv )had no water coming out of the refill tube.i took it apart, and saw no way it could.Is this normal for this unit?
    Top Expert:
  • Sterling Master
  • 75,822 Answers
Since there is no way to change the designed in flushing water flow of the toilet the only real option u have is to replace it, many low flow (2-3 gallon flush) have this problem, the very newest designs by many manufacturer's address this issue but none but the pressure flush models (which are very pricey) really work as good as the old high water usage toleit's. Go to the link below to look at the best of the low flow toilet's o0n the market.
http://www.consumersearch.com/toilets
Posted on Apr 21, 2009
  • 15,935 Answers
If you pour a bucket of water in the toilet during flushing - does is drain properly - or fill up and almost overflow the bowl??
If it drains properly - the problem is in the toilet. If the water sucks out - the problem is with the drain - clogged or poor vent.
If its the latter - check your main stack vent for rodents - leaves etc.
Any blockage will not allow the drain to form properly.
If it is filling up the bowl - you may have some lime buildup at the filler holes under the lip - or (if there is one) at the bottom Jet.
Take a wire coathanger and poke away at the small holes around the underside of the lip to be sure they are clear, and the toilet is filling at the proper rate.
Also do it if there is a jet at the bottom of the bowl.
If you have additional clarifications about your question - please use the "continue with this expert" selection so we are reconnected in the future.
Thanks for using FixYa!!
A USEFUL TIP FROM ANOTHER SITE:
Lets discuss how a toilet works. A toilet has a built-in trap. Just like the ones under your sinks. A "U" shape that holds enough water to seal out sewer gases. When the toilet is flushed, it takes all the water and whatever else is in the bowl and pushes it through the trap and when the trap is full again, all excess water goes down the drain.
There are a couple things that may be happening to you.
1) The holes in the rim (underneath) are partially clogged and not allowing enough water to flow at one time to complete the flush. Cure: Turn off the water supply under the toilet. Flush the toilet. Lift up the flapper in the tank and pour a bottle of vinegar into the hole where the flapper is. Let this sit for as long as you can. Take a mirror and a bent metal coat hanger and push through eack hole under the rim. Turn the water back on and flush.
2) The flapper is not staying open long enough to allow the tank to totally empty. Cure: Adjust the chain from the handle to the flapper so that the flapper "just" seals. This way, when you activate the handle the flapper will stay open longer.
3) If the water level raises when you flush, there may be a clog or partial clog in the toilet piping. This will have to be snaked out or PERHAPS an enzyme drain cleaner used to "eat" the clog.
Good luck and let us know how this works out. You can do these in any order you wish.
Posted on Apr 18, 2009
    President:
  • 1,902 Answers
If your toilet fills to proper level and you are still having issues of flushing with the swirl then it is a problem with the plumbing. What you can try and do is take the float and bend it up slightly and make for more water in your tank. I dont believe that this will solve your problem though
    Genius:
  • 1,847 Answers
This is happening because water is not flowing with presser to the pot. the torbeck valve needs replacement. that will fix the issue.
Let me know ....
Thanks
K
How do you adjust the clip so the water level increases?
You don't adjust the clip as it attaches to the pipe to automatic turn off the water at the right level, but your water may be set at to high a level that it overflows into the bowl. When that happens you can do 2 things to correct it: 1 at the wall where the cold water comes out to the toilet you can adjust it to slow the supply of water to a little less. 2. You can adjust the screw inside tank to tighten (turning screw one way) to adjust water level to shut off quicker or adjust tank screw the other way to fell take water up higher. Flush the toilet and observe the power of the flush. Allow the tank to fill until the water shuts off. Repeat the procedure to adjust the float and water level, if desired.
Apr 26, 2014 | Plumb Craft Waxman 7030700T Perfect Flush...
Tip
How to adjust a toilet
  • Your toilet tank may simply need a good "tune-up." Here are some adjustments you can make.
  • Refill valve. If your tank has a conventional ballcock refill valve, the water level is adjusted by bending the float arm. The level should be high enough for complete flushes, but the water should not be to the top of the overflow pipe. Your tank should have a colored or molded water level mark. It should never be set so low that the bowl does not refill with trap sealing water. The rule of thumb is to set the water level about 3/4" below the top of the overflow pipe.
  • If the float rubs on other parts, simply adjust the float arm sideways. If the float lacks buoyancy, unscrew then shake it to determine if it is waterlogged. A waterlogged float should be replaced. The float arm can also be replaced, if needed.
  • In tanks using modern plastic refill valves, the tank water level is adjusted in other ways. If your tank uses a hand nut, turn the nut clockwise to raise, or counterclockwise to lower, the water level. Or, your tank may have a sliding pinch clamp on an adjustment rod.
  • Flush valve. Replacements for a flush ball and its actuating mechanism are available, but it may be possible to stop a leak with minor adjustments. Check the following mechanisms before purchasing replacements.
  • See that the guide arm is centered directly over the seat. The guide arm should drop the flush ball directly into its seat. If the flush ball is not seating properly, make the adjustment shown.
  • The guide arm should allow the flush ball to rise enough for a complete flush. If not, raise the arm. Be careful that it isn't too high–then it will prevent the ball from closing completely.
  • Check that the upper lift wire pulls the flush ball high enough. To adjust it, simply bend the wire for a higher or lower lift.
  • The lifting hardware on a flapper-type flush valve should raise the rubber flapper to start a flush, but should not hold the flapper up off its seat. If this is occurring, the hardware is adjusted too short. Some types allow you to slide the flapper itself up or down on the refill tube to ensure that the flapper meets the valve seat squarely. The lifting hardware and flapper height adjustments are the first things to check when flapper problems arise.
  • Refill tube. If the bowl-refill tube is out of place, water is routed directly into the tank, rather than replenishing water in the bowl. When this is the case, you will likely hear splashing sounds during tank refill. The refill tube should aim directly into the overflow pipe but should not reach below water level. If the tube extends too low, it will siphon tank water silently away. Fix it by repositioning as shown.
  • Defective refill tubes on some valves can be replaced with new plastic ones. Simply place one end of the plastic tube over the serrated plastic lug on the body of the valve, and place the plastic holder in the top of the overflow pipe.
  • on Jan 16, 2010 | Plumbing
    We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
    The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
    Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
    Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
    Toilet runs continuously or doesn't flush adequately
    Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
    Check the Chain
    The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
    Check Water Level
    Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
    Clean the Surface of the Flush Valve
    A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
    Replace the Flapper
    Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
    This video will help familairaize you with the flushing mechanism and the repair:
    Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
    When flushing the toilet, there is not a lot of "push" behind the flush. I'm having to flush two times, regardless of what is in the toilet.
    It is normal for these useless new tanks to do that. Won't even flush a piece of paper. Pull off the lid and make sure the little hose is in the overflow pipe, and raise the water level as high as you can. take out all the bricks and water bottles, and bowl cleaners. Then give it a try. It might do a bit better. Hope this helps.
    Jul 03, 2010 | Mansfield Plumbing Products Mansfield...
    The toilet cistern is filling up but the toilet pan is not getting enough water presure to empty
    check that the water in the cistern is up to the mark etched on the inside
    Do you have a close couple or a washdown [with pipe from cistern to pan]
    Mar 04, 2010 | Home
    I have a new sterling 1.6gpf toilet can I increase the amount of water in the bowl. Every time or almost everytime, waste sticks to the bowl and I have to brush it loose.
    If you raise the water level in the tank it will double flush. I suggest you change out the toilet to a Toto or Kohler class five flush action.
    Nov 13, 2009 | Sterling Home
    Increase water in toilet tank-low flush Toto toilet
    Yes adjust the float level to raise the amount of water in the tank, If you have a float that is a ball around the tank you will have to turn the water off and remove the hose from the tank and remove the nut then pull the water float device out and you will see a clap on the bottom of the float you will turn the float base so that it gets longer, increase it by two inchess so that you increase water flow. Reinstall into the tank hook it all back up and leave the lid off turn on the water and watch the water level rise be sure the float shuts the water off before it over flows, if it starts to over flow then fush it to bring the water down giving you enought time to shut off the water valve.
    There is a problem adding low water systems to older septic systems. The septic pipe settles in the ground over time and may cause a ~~~ in the pipe thus causeing blockage. For future reference you can add a one gallon bottle of water in the tank like a milk jug or a used up bottle of puerified water that you have drank and this will decrease it by one gallon per flush. Hope this helps. If you need more asstance just posttothis reply!
    Nov 11, 2009 | Toto Ms874114sg-12 Carlyle Toilet With...
    This is a commercial toilet with a g-2 sloan valve on top. The amount of water dispersed is fine, but there is something wrong with the throat of the toilet, I think. The drain action is somewhat slow...
    The blockage MAY be beyond the length of the snake you used. Once I had a blockage that required 145 feet of snake. ALSO the vent could be plugged by any of several things, including wasp nests.
    Nov 04, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
    Home Logo
    147 people viewed this question
    Top Sterling Home Experts
    Tim Whalen
    deton8 von Splosion
    Are you a Sterling Home Expert? Answer questions, earn points and help others
