Question about Sony Handycam DCR-TRV265E Digital Camcorder
Pass through how do I use this camera in pass-through mode?
  • ratface Sep 17, 2007
    I dont have the manual
    Sniper:
  • 133 Answers
Convert and/or record any analog PAL video source to digital video via the analog inputs. Analog PAL video can also be passed through the Digital Handycam® camcorder directly into a PC via the i.LINK® interface in real-time for easy PC editing of your analog footage
Posted on Sep 17, 2007
  • scott gregg
    scott gregg Sep 17, 2007
    http://www.docs.sony.com/release/DCRTRV4...
    pages 86 and up explain using the hook up for passthru, using the ilink cable
  • scott gregg
    the link is for the manual
SOURCE:
Tip
How does aperture setting affect a photograph?
The aperture is the opening in the lens through which light passes to the image sensor. Changing the aperture setting allows you to control the depth of field of a photograph. When the aperture is opened to a widersetting, (indicated by a lower f-stop number) more light is passed to the imagesensor, creating more shallow depth of field. Closing the aperture (indicatedby a higher f-stop number) allows less light to pass to the image sensor,creating wider depth of field.
NOTE: The aperture setting is one of three primary settings usedto control the overall exposure of a photograph. The other two primary settingsare ISO and shutter speed. Because the three settings work together to produce the overall exposure for a photograph, changingthe aperture setting will require complimentary changes to either the ISO or shutter speed to produce a properly exposed photograph. These changes will bemade automatically by the camera in the Auto, Program, Aperture-priority andShutter-priority modes.
There are two ways tocontrol the aperture setting on the camera:
  • Aperture-priority mode (A) - When shooting in Aperture priority mode (A), you set the aperture value and the camera automatically sets the optimum shutter speed for you.
  • Manual mode (M) - When shooting in Manual mode (M), you control both aperture and shutter speed, which gives you maximum creative control to achieve the exact results you want.
on Jan 08, 2011 | Cameras
How to take videos in wide angles on polaroid is426
go in to menu scroll to panarama mode press set go back to picture mode you should have wide mode
Feb 13, 2015 | Polaroid Is426 16 Megapixel Compact Camera...
Is there a factory reset
Normally you have to send it in to Bushnell and have them do it for a fee but in the past I used the following to reset a similar Bushnell trail cam and it may work for you:
1. Turn camera on and wait for the password screen.
2. Press and hold the enter button until the camera switches to the 5 digit password mode. "Trail Sentry cams will not indicate a 5 digit mode on the screen, but it will show "-----".
3.Press enter to confirm 5 digit mode.
4. Enter the 5 digit code "66214, then press enter. *Note it will accept a 5th digit.*
5.Camera should display "PASS" and go into the operating mode.
From here you can program a new password from the setup mode.
Nov 08, 2014 | Bushnell Trail Sentry 11-9200 Digital...
How do I change the password
2. Press and hold the enter button until the camera switches to the 5 digit password mode. "Trail sentury cams will not indicate a 5 digit mode on the screen, but it will show "-----".
I get (have) a black screen when I put my camera in the on position to take picture/video. I can view all pass picture/video, If I switch mode to view. when I switch the mode to take picture or video I...
Try hitting the display button(the small TV resembling icon in the bottom right of the camera). You may have accidentally pressed it while using your camera and caused it to turn off your display.
Mar 07, 2011 | Sony Cyber-Shot DSC-M1 Digital Camera
My pass word on my trail camera shows error I was trying to set the date with the default password... May have screwed up the password in the process How do I reset the camera??
To reset the password:
Turn unit on and wait for password prompt
Depress the and hold the enter button until camera switches into 5-digit password mode _ _ _ _ _.
Trail sentry systems will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th digit is entered in the _ _ _ _ screen.
Camera will now go into operating mode, and user can now program a new password from the setup mode.
Follow this link to see the user manual PDF:
http://www.bushnell.com/manuals/trail-scout/119000TrailSentry_manual.pdf
Jan 29, 2010 | Bushnell 11-9000 Digital Camera
Decode to reprogram new pass word
Try this:
Trail Scout and Trail Sentry camera re-programming procedure.
1) Turn unit on and wait for screen to prompt password
2) Press the enter button and hold until camera switches into 5-digit password mode _ _ _ _ _.
Trail sentry cameras will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
3) Press enter to confirm 5 digit mode (for trail scouts go to next procedure).
4) Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th 0ne is entered in the _ _ _ _ screen.
5) Camera will now go into operating mode, and user can now program a new password from the setup mode
Sep 30, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Dont know password to my 119900 bushnell camera
Hello, Brian Artz here,
I have received hundreds of e-mails on this password problem. to many to reply to so i will post how to gear up all of us
trophy takers..
1. TURN ON UNIT AND WAIT FOR THE SCREEN TO SAY PASSWORD
2. PRESS AND HOLD THE ENTER BUTTON UNTIL THE CAMERA SWITCHES INTO THE 5 DIGIT PASSWORD MODE,
##NOTE## SENTRY CAMERAS WILL NOT INDICATE A 5TH DIGIT MODE ON THE SCREEN BUT WILL SHOW
"_ _ _ _"
3. NOW PRESS ENTER TO CONFIRM 5 DIGIT MODE
3A. THE CODE IS "66214" FOLLOW THE PASSWORD ENTRY PROCEDURE AND PRESS ENTER AFTER THE LAST DIGIT "4"
4. CAMERA SHOULD NOW SAY PASS AND YOU CAN NOW CONTINUE TO PROGRAM A NEW PASSWORD YOU WONT FORGET THIS TIME
Oct 25, 2008 | Bushnell Trail Sentry 11-9200 Digital...
Sony DSC W7 control dial defect
I had a similar problem with my EOS 5, was trying to change between modes and it made a lovely "snapping pencil" noise and then behaved as you describe. I managed to get it done under warranty after a lot of moaning and ****(it was 54 weeks old). After chatting to some camera shop owners it seemed to be the most common problem with the EOS 5 (doesn't happen often, just most common type of error). I could understand it if I was going from the program modes to the creative modes where you have to pass through the "lock" position, but I am sure that I wasn't. Anyway, upshot was that it got fixed, works fine now, but when changing modes I always depress the "lock" button, even if its not passing through the "lock" position. Sorry, but the quick fix is pay the $75 which doesnt seem unreasonable, or switch to a camera that doesnt use that type of switching method, EOS3, EOS1, EOS D3 :-). Hope this helps to answer your question
Mar 05, 2006 | Sony Cyber-Shot DSC-W7 Digital Camera
Sony Handycam DCR-TRV265E Digital Camcorder Logo
678 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
