Question about AT&T Lands Phones
ATT 00376-Cordless Phone Not Charging
The phone handset is dead and shows not to be charging in the charger. I removed the original rechargeable battery (Model 2420) and reinserted it, it begins to work, and when placed in the charger, it then shows to be charging. However, after a few minutes the handset goes dead and the "Charging" light is off. I've replaced the battery twice, but each time when I place the handset with the new battery in the charger, the screen flashes "Check Battery", the "Charging" light is on, but it never charges. Any suggestions?
4 Suggested Answers
SOURCE: Although charged my Samsung ATT phone just stopped
try changing ur battery or jst remov ethe battery insert it again and then restart the phone
Posted on May 07, 2009
SOURCE: phone not charging even with new batteries
Reboot your phone system. I'm not kidding. Unplug base from power and phone line for 1/2 hour and unplug battery from phone.
Posted on May 19, 2009
sharna banna
  • 51 Answers
SOURCE: My battery won't recharge once it gets drained.
you may need a new phone because it has definetley worn out so yeah
Posted on Dec 19, 2009
All of a sudden screen went blank charger is plugged in not charging.please help me
Most likely, your rechargeable battery went dead. Replace the battery, charge it fully overnight, and the phone should be fine again.
May 14, 2015 | Uniden DWX337 DECT 6.0 Waterproof...
Need to know about cordless phone seervice centre
Usually when made they come with rather poor quality rechargeable batteries in them to save money.
Lots of sellers on EBAY from China etc are selling them now there, got two of the packs, open phone, unplug, remove battery pack, install new on.
I got a few that came in five days from Hong Kong duty free for under ten dollars for two sets of the batteries.
My money would be the batteries are trash.
Usual life on new original ones about one year.
Dec 15, 2012 | Uniden Cordless Phone
Red light indicating fone charging has not shut off for around 20 hours.
My Vtech 6.0 charging light only turns off when I remove a handset from the charger base. I have had these three set for two years and they work fine. I think that the red light is just to let you know that the charger is working, if you loose power, or unplug one of the base units there is no indication of a dead battery.
Jun 11, 2011 | Vtech Cordless 6041 Phone
I have a uniden 5.8GHz cordless phone with 3 handsets. But now 2 of the handsets do not work. The base lights up to show it is charging and when I pick up the phone, the handset says...
You may have a problem with your battery. Usually the rechargeable battery goes bad on those units. Swap the battery from the working handset to one of the non working ones.
Dec 16, 2017 | Uniden 5.8GHz Cordless Phone
My phone is display out of range
  1. hi..
  2. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
Jan 03, 2011 | Uniden Cordless Phone
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
TRU8885 in Australia Charger/Power Adapter Issues
try to re charge on base. phone contacts base and hand set may require cleaning. the charging light may have separate circuit and may not be in series so you may get false indicator. the 1000 ma is good current and should charge correctly.
Jul 21, 2008 | Uniden TRU8885-2 Cordless Phone
Uniden phone
That sounds like the battery is not charging properly. When in the charger there is enough voltage passing to power the handset, but when pulled off the charger it must rely on just the battery. I suspect you replaced your battery because you were having a problem, right? Your problem may be dirty charging contacts. Try taking a pencil eraser to your charging contacts on your handset and base. Try charging your handset again, and ensure your charge light comes on when doing so. Let it charge overnight. Hope that helps. CG
May 26, 2008 | Uniden Cordless Phone
Phone charging indicator light
register phone instuction
May 22, 2007 | GE 25861GE3 Phone
Lands Phones Logo
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
