Question about Symphonic SL260A S-VHS VCR
Vcr problem when i put a video in to play or to record it the vcr shuts off.
  • 2 more comments
  • carlmart Nov 02, 2007
    My problem seems similar. It may happen in play or in record condition.
    You press the play button, it seems to try to read and then shuts-off.
    It happens with several tapes, so it shouldn't be a tape deffect.
  • Maxee Nov 14, 2007
    My RCA 4-head VCR plays commercially-produced tapes, but does not play (or record) blank tapes that I have purchased in order to record. The machine starts to play them for a few seconds, then shuts off. But commercial video cassettes play just fine.
  • vtgal Apr 14, 2008
    when I try to play or record a tape it shuts off after 5 seconds. help
  • arreglador Jun 25, 2008
    Tape seems to load well. Plays for about a half-minute, then it stops and turns off. Have opened the top and the tape does not fall all over the place, but it does not seem to want to play.
For more ideas, you can try this website: ( http://www.fixer.com/ ). They have VCR categories sorted in a database by Brand and Model Number, as well as an overall directory of problems and solutions. Most helpful thing I found was a schematic identifying the various inner workings of my VCR. Hope this helps.
Posted on Jul 17, 2008
    Novelist:
    Champion:
  • 254 Answers
This usually indicates an error condition- the logic is sensing an abnormal condition. Suggest taking the top cover off the VCR, and load the tape, then activate play. Does tape begin to spill out in the mechanisms, especially towards the right side of the tape? If so, then the take up spindle isn't being engaged to take up the tape. This at least was, a common problem with VCRs, especially older ones ('80s era) which used a rubber drive wheel. This rubber "tire" like drive would become slick & hard, and would cause a no-takeup condition, spiling tape out. There was a sensor which told the logic circuit if the takeup wheel was indeed turning, and if not, the VCR would be taken into a stop or shutoff mode. This sensing would prevent large amounts of tape spillage and the resultant damage such would do. Another possible cause is the tape isn't being loaded properly. This is generally due to a defect in the carriage mechanism (the assembly which holds the tape). Often, these mechanisms were gear driven. Timing on these gears is often critical, and being off by just one tooth would cause an error.
Posted on Sep 17, 2007
How do I record from the VCR to the DVD?
Do you have your owner's manual? If not:
FUNAI 2014
It talks about the types of CD's/DVD's you can use and which modes to have it set to, restrictions and so on. Then troubleshooting starts on Page 84 of the .pdf file.
I hope this helps.
Jan 27, 2015 | Funai ZV427FX4 DVD Recorder/VCR - 1080p...
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
Sony rdr dvd recorder / vcr combo.... I put a instructional video and the dvd won't go past the copy write warning.
have you checked the cd for deep scratches because i had a dirt bike game that did the same thing
Mar 05, 2013 | Sony RDR-VX525 DVD Recorder/VCR
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
VCR connected to a TV, I can play videos from the VCR to the TV but cant record programes from the TV to the VCR
first put antena cable{aerial} in vcr,after this you must programing the vcr and then you can record from tv...
Dec 28, 2010 | LG RC897T DVD Recorder/VCR Combo
When I record a movie on the vcr it plays back snowy.
Ur VCR signal recorded free air throught an DTV converter box?Yes,this cause is normal,because VCR player have no digital tuner on the VCR player by itself,on it circuitries design.If recorded throught pay cable signal.Yes,than ur VCR video head player is dirty needed to be clean.Tries websites like Amazon.com,Ebay.com to buy a VCR video head cleaner vdeo tape.Just play it as normal as a video tape,when the video head clean,VCR will display clean head eject tape now.
Aug 03, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
We put a tape in vcr. we push record and the vcr ejects tape and shuts off.
Does the tape play normally? Does this happen with several tapes when you try to record? Check the record protect tab on the lower left hand side on the facing end of the tape. If this is broken or bent it will not record, you can put a piece of tape tightly across the tab as a repair
Oct 01, 2009 | Philips Televison & Video
How do I set it for dubbing from another vcr?
Use a RCA cable put it in the Audio,Video OUT of the playing VCR play the tape.Use
the other side Audio,Video IN the recording VCR.
Aug 25, 2009 | Symphonic SL260B VCR
Can't find VHS video recording when I press play on VCR.
make sure your VCR is on the right channel TO record.
You may see the picture on the televison, but that doesn't mean that it is recording that channel. Also, make sure your tapes have the little plastic tab ON on the front of it. It will not record without the plastic tab or you can use a piece of scotch tape and put over the square hole.
Are you using coaxil cable or rca jacks to hook up vcr to tv?
Mar 11, 2009 | Televison & Video
VCR will play, but not record.
You gotta connect the signal cable to the input of the vcr and in the output of the vcr other cable to the tv input,when you got to record some program you need put the channel number on the vcr not in the tv if you conect the vcr to the tv in the avinputs the tv will be in video mode,because the vcr receipt the signal.
Good luck
Apr 13, 2008 | Samsung DVD-V5500 DVD Player/VCR
Symphonic SL260A S-VHS VCR Logo
163 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
