Maytag SAV515DEWW. leaks only on discharge. doesn't leak upon filling/washing, only when it gets ready to rinse/spin
    Genius:
  • 1,011 Answers
Dear,
it seems that the leakage seems to be coming from the large aluminum casting (transmission?) directly below the wash tub. did u check that...
Might be seal is shot, the aluminum piece that fits inside the seal is scored up and the bearing is totally whopped out.
seal pic is here,,,
check it by the way and let me inform if case is different...
regards,
Posted on Apr 17, 2009
  • 2 more comments
  • SALMAN NASEER Apr 17, 2009
    here is the image
    removed the lower front cover on the machine and began a cycle to find where the leak is coming from....
    for your help iam going to send u the complete procedure to deal it...
    hope it will help u alot to rectify the problem
    1. UNPLUG THE WASHER FROM THE POWER SUPPLY.
    2. Remove the lower front panel from the washer.
    3. Remove the upper front panel from the washer.
    4. Lift the top cover on the washer - the entire top of the washing machine should pivot backward.
    5. Remove the softener cup from the top of the auger. It snaps off.
    6. There is a 14mm or 9/16" bolt in the center of the auger. Remove the bolt.
    7. Remove the auger. It should slide off if you pull straight up and wiggle as you pull.
    8. Remove the 3 bolts around the base of the wash tub on top of the lint trap (gray plastic frisbee looking thing).
    9. Remove the lint trap and throw it away. That's probably what caused your bearing failure in the first place - it allows sand to pass through and get to the seal. The repair kit comes with rubber plugs to fill the 2 holes (stainless tub) or 8 holes (plastic tub).
    10. Remove the cast aluminum hub (hammer & prybar is what I used). It spins off lefty-loosey but you'll probably need to beat on it a bit to get it to go.
    11. Remove the wash tub - it lifts out exposing the seal and bearing pack in the plastic tub.
    12. Remove the six (6) 5/16" screws from the plastic tub. Disconnect the hoses (one at the back side of the tub, one on the bottom) and remove the tub from the machine frame.
    13. Knock the bearing out of the plastic tub. I used a 3" PVC pipe coupler on a short piece of 3" PVC pipe to support the tub while I hit the old bearing/seal pack with a hammer (lightly) to knock it out.
    14. WASH ALL THE PARTS (plastic tub, wash tub, auger, etc) with water to remove any garbage on them (sand, lint, etc). You want to put clean parts back together!
    15. Put a little bit of sealant on the outside diameter of the seal pack (I used the silicone gasket material I use for rebuilding engines) and install the seal pack into the plastic tub.
    16. GREASE the inside of the seal and the outside of the washing machine transmission shaft and reinstall the plastic tub. I used marine wheel bearing grease - the same stuff I use to repack and lube the wheel bearings on my boat trailer.
    17. Repeat the disassembly process in reverse order - the instructions that come with the kit should get you home from here... in terms of instructions, they are pretty decent and have pictures to help.
    In the end, the instructions that come with the Maytag kit tell you to throw away the lint trap and not reinstall a new one. I seriously think the lint trap allowed the sand to pass through the screen and accumulate on top of the seal.
  • SALMAN NASEER Apr 18, 2009
    Dear,
    are you performing sometime as i suggested....
Leaking underneath
Give a lot more detail. Make/model. When does it leak, upon filling, upon emptying, all the time. How much leak, small amt, huge amt, etc, etc
Apr 03, 2015 | Maytag Washing Machines
During wash cycle of my Maytag Legacy SAV515DEWW, tub moves freely and after spin cycle, tub keeps spinning for a while.
Maytag has a drum brake located on the bottom of yor machine. You need to remove the brake and clean it up or perhaps replace the device.
Google Maytag washer drum brake for several "how to"sites
Nov 30, 2014 | Maytag Washing Machines
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Water leaks when filling
Use a putty knife at the top front corners to release the spring catches. Lift up the top. Examine the plastic thing that delivers the water to the tub, it may be cracked or out of place.
Apr 05, 2009 | Maytag LAT3600A Top Load Washer
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Maytag doesn't seem to rinse.
Try this. Run the machine set for full load, short wash. DO NOT put clothes or detergeants in the tub. Water only. Let the machine agitate for 1-2 minutes. Gently advance the timer manually untill it locks into spin. Let the machine continue to spin until it stops on its' own and begins to refill. At this point lift the lid and see if there is any access water in the tub.
Most of the time this condition is caused by a blackage in the drain line. Make sure the drain hose is not kinked in any way.
Also, there are times when I've had to removes socks and other objects from the tub to pump hose. It only take a 10% block to cause the machine to retain water.
Nov 20, 2007 | Maytag SAV515DE Top Load Washer
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
