Question about Refrigerators
Door is rubbing at the bottom of fridge. Can it be adjusted?
Is there a way to adjust door? It's rubbing at the bottom. Door is not closing properly?
  • 121 Answers
There is a kit that goes at the bottom hinge that will lift the door
Posted on Apr 17, 2009
How do I realign the fridge door with a top mount freezer
The top to bottom alignment is done by moving the hinges up/down. On many models there may also be plastic spacers on the hinge pins you can use to adjust the height.The closing of the door so it shuts properly and is flush on all 4 sides is done by adjusting the screws that hold the door gasket in place. If you've never done it before it can be a real pain to get it right. Make small adjustments to the screws and if need be grab the door at the center top and center bottom and give it a small tug in opposite directions to get it straight, if you have to. To test if its closing properly, look at the edge of the gasket all around it should be the same distance from the body of the fridge, use a mirror to see the bottom. To test if its sealing properly use a dollar bill. Close the bill in between the gasket and the door in areas all around the door, When you pull on the bill you should feel resistance, if the bill is not held in or pulls out easily the gasket is not sealing properly at that location, you need to adjust the screws to get it aligned better.
Feb 26, 2015 | Refrigerators
Amana XRBR206BB
The bottom hinge may have to be adjusted or shimmed.
Feb 09, 2014 | Heating & Cooling
Adjust door on kenmore 22
Your Fridge need be leveled and door need be adjusted after fridge is leveled
Dec 06, 2013 | Kenmore Refrigerators
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
May 04, 2011 | Refrigerators
I have an Inglis fridge and when door is closed there is about a1/8 of a inch space between the seal at the top and fridge . Bottom seals properly
That can be caused by hardening of the bottom seal due to ice build up in the seal or the door hinges need adjusting by loosening the lower hinge and pulling it out slightly to compensate for the door seal.
Mar 05, 2011 | Microwave Ovens
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Refrigerators Logo
306 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
