Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP Officejet 6210
My HP Officejet 6210 ia approximately 2-years old. My printer stop printing a few days ago. It shows "Paper Jam" error. I removed the back inspection plate and cleared the initial jam. Afterwards, the paper feeds thru about 45-50% and the "Paper Jam" error re-appears. Also the top right corner of the page comes out slightly folded and creased. Please help, I love my printer. Thanks, Doug
    Problem Solver:
  • 9 Answers
It could be your rollers need to be cleaned or a input sensor could be going out
Posted on Sep 19, 2007
  • 62 Answers
Hi, I can help you with your printer problem. Please open this document and follow the instructions to the letter. http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=fi&cc=fi&dlc=fi&product=12019&docname=c00249509 Let me know how it goes. Good Luck
Posted on Sep 17, 2007
SOURCE:
My brother dcp-560cn keeps jamming and making noises as if it is destroying itself have cleared all paper from jam and it still jams why is this
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | HP OfficeJet 6210 All-In-One InkJet...
PAPER JAM. NO PAPER IN MACHINE BUT STILL GET PAPER JAM SIGNAL. OCCURRED IN MIDDLE OF PRINTING PG 2 OF 2 PG JOB. I CAREFULLY REMOVED THE HALF-PRINTED SHEET, PRESSED "OK" AND IMMEDIATELY GOT "PAPER JAM"...
the first step you should do is.
> unplug the power cable from the printer and then plug it back in.
> clean all the rollers which are there.. front rollers, adf rollers.. rollers at the back ..
> if does not work then. perform a reset.
( unplug the power cable from the printer while the printer is on. and after that press and hold the 6 and the # key on the printer. while holding and pressing down these keys plug in the power cable and wait fr 20 secs and then release the buttons.. )
this is a reset..
after this reset it will take few minutes to initialize.
These steps will possibly resolve the issue.. if not i must suggest to to get a new printer..
Oct 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper jam
Found this on the HP Web site.
Issue:
The product stops printing and the error message 'Paper Jam: Clear jam, and then press OK ' displays on the product.
HP Support
GOOD LUCK!
Oct 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6110 (4 years old) makes short grinding noises during printing. Occasionally the printer stops and asks to have the door opened and the jam cleared. The problem is gradually getting worse....
Try first to clean the encoder strip. It's the clear strip behind the printhead. Either use a Q-tip dampened slightly, or small towel. Don't apply too much pressure though, it can come off and they are hard to put back.
Jul 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper jam
Remove back part of the printer. View the printer roller usually in the heater area, if there is still small particles or paper left.
Mar 02, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper Jam Error when there is none
look in the rear of of the printer for an access door with a big knob to remove it.
Jan 02, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Machine shows "Paper Jam" error
There is a paper senser present in the paper lifting area. That part of your printer is not working properly. Replace that part and then try
Sep 20, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
275 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
