Question about Logitech QuickCam Express Web Camera
Lighting problem with logitech quickcam
Hi. I purchased a logitech quickcam. I have problem with light settings and it doesnot work propertly at night unless it has great amount of light which makes working inconvenient. Plz suggest a way out.
  • 4,924 Answers
Try to fix from the settings...it does have some kinda settings that allow ya to fix the light ....clic the low light case....you can not miss it ...and gave it more bright and contrast ....
you can also bright it up from gamma ...
so....remember file/preferences/camera settings....etc...
and ussualy it can be put to remember setings...and when you open it ...and is not setted right ...just clik restore....
I sincerly hope this will fixx you problem ...I adviced you in how they generally work ...but I am not familliar with the model ....and they are having differences from on emodel to another...its ussualy small and it depends of the kinda driver they use....
but in most of them ...you find those settings when you use it on IM ....
Posted on Apr 17, 2009
The picture is too dark from logitec classic cam
hi i had the same problem with mine, this can be overcome by an external light source ie, a lamp or a brighter room light, make sure that it is not facing towards a window like having the window behind you as this will then set off the light reduction setting in the camera, but light coming from behind the camera is better...hope this helps
Feb 25, 2010 | Logitech QuickCam Express Web Camera
Blurring during realtime movement
Try a different USB port if you can.
Check the lighting, to make sure you do not have "low light" conditions, that will affect the picture in a similar way.
Check the focus ring on the front to make sure it is set right.
http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
Dec 18, 2009 | Logitech QuickCam Pro 5000 Webcam
My camera quit working in skype, any suggestions in troubleshooting? the green light isnt coming on at all, it was working like 5 minutes ago
To test if the Logitech QuickCam is functioning, check the USB cable, make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Also check the Audio Settings for the Microphone THEN click on Save.
Dec 14, 2009 | Logitech QuickCam Connect Webcam
How do you adjust lighting and color on a Logitech webcam
turn off right light and all of the controls go to manual, settings>rightlight settings>uncheck box
Jul 08, 2009 | Logitech 961462-0403 Webcam
Blurry pics
Did you make sure the lens was clean? Wipe lens off the reset the webcam to its default settings. Slowly adjust the focus ring for best effect then adjust the video settings.
Mar 07, 2009 | Logitech Webcam
Logitech quickcam zoom with vista?
I haven cheked this ,
this is a patch to make your webcam compatible with vista.
try this
http://www.logitech.com/pub/techsupport/quickcam/qc1150.exe
i m sorry if it doesn work becos i don ve the webcam to check wit the patch
Sep 20, 2008 | Logitech Quickcam Zoom 5 Pack Webcam
QuickCam Express, blurry, snowy picture...sometimes the picture is totally shaded red
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens.
This will allow you to focus the camera image on objects at different distances.
Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video.
Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed.
Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds.
If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter.
For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher.
To change the color palette please perform the following steps:
Click on "Start," "Settings," and "Control Panel."
Double-click on the Display icon.
Click on the tab labeled Settings.
In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost."
If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software.
To do this:
Open the QuickCam software.
At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
Choose "Advanced Camera Settings".
Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
Click OK when your are done.
Last, make sure that you ae using the latest drivers.
You can upodate them from here.
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Logitech Webcam
Image quality
Connection Issues:
Low Light Boost:
To do this:
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Logitech QuickCam Chat Personal Web Camera
Shows Dark
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Jan 13, 2008 | Logitech Quickcam Chat Webcam
Fuzzy picture
when using a video recording programme, the backlighting is normally automatically done for you but in live messenger you have to set the camera up yourself, as the fuzziness you are experiencing will probably be the lack of lighting in the immediate vacinity, so within the camera software before you go online, go into the settings and change the backlighting, most cameras have this option, also check the options in messenger, or make sure you are well lit around youself especially at night.
Jun 17, 2007 | Logitech QuickCam Fusion Webcam
Logitech QuickCam Express Web Camera Logo
73 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
