Question about Refrigerators
WATER POOLIN AND FREEZING AT ON FLOOR OF FREEZER. ICE MAKER NOT HOOKED UP
WHIRLPOOL FREEZER EV171NYMSO2 WATER POOLS AT THE BOTTOM AND FREEZES. ICE MAKER IS NOT CONNECTED. ON OCASION WILL HEAR A LOUD POP FROM REAR OF CABINET. FAN WILL RUB AGAINST WALL ONCE IN A WHILE. UNIT IS FOUR YEARS OLD. KEN
  • kenbest462 Apr 20, 2009
    I'M BACK IN BUSINESS.! FROZEN DRAIN LINE... AS YOU SAID..
    THANKS FOR SAVING ME A SPENDY SERVICE CALL... kb
  • 121 Answers
You have a blocked drain remove back freezer panel
at the bottom you will find a lot off ice remove it with hot water and clean drain hole the pop is the ice cracking
Posted on Apr 17, 2009
  • lojacksdad
    lojacksdad Apr 20, 2009
    your welcome
    flush that drain every once in a while
This is a side by side refrigerator/freezer with water freezing on the bottom of the freezer as well as water pooling under the freezer area & seeping out the side and front of the freezer on the...
defrost wiring problem, defroster stuck on or timer not working properly , eventually wires may short out. Had this problem on my whirlpool
Aug 02, 2009 | Refrigerators
WATER AND ICE INSIDE MY FRIG
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
These are general instrutions for most top freezer refrigs. but if you need more specific directions dont hesitate to ask Thanks Peyton
Mar 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
WATER pooling in bottom of fridge
did you try to remove the 2 ***** in freezer floor???. if not remove the floor and check for ice build up underthere, if so:
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 12, 2008 | Whirlpool ET8RHMXKQ Top Freezer...
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
184 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
