Question about Saeco Magic De Luxe Espresso Machine
Would like to descale my machine without descaling solution, is this possible?
  • 41 Answers
Ok guys this is my own opinion on descalling and I have to tell you firstly I have been repairing saeco machine for over 8 years so I think I know a bit about them by now. Scheduled Descalling to me is a waste of time and money, now I'M NOT saying to "never descale your saeco" but when that descale light or word comes up on your machine it does not necessarily mean your machine needs to be descaled. Your Saeco machine DOES NOT have a magical sensor inside that tells you there is calcium build up inside the boiler. All Saeco machine use a timer device built into the Electronic main board. As a pre set number of coffee's are made, Saeco has set a timer to bring up either a light or Symbol on screen to tell you your machine is in need of a descale. Now with different countries , States and living conditions not all water outlets consist of the same water purities, so how can Saeco say at a certain time your machine needs descalling? ( Saeco's are built in Europe were most places you wouldn't be caught dead drinking their tap water ) . I can only go by experience where I repair machines in Australia (Melbourne) and I have had many machines fail due to being constantly descalled. How many of you have been having a good run from your machine until the day you thought you had better off descale your magic deluxe as it hadn't been done in a while. Upon descalling the machine you hear and see water leaking from the unit and Bang , the machine stops dead , or if your very lucky you shut the machine off just in time before the circuit board gets wet and you send the Deluxe to Saeco and now your up for a new boiler and service.
What had happened is that in time the seals of the boiler have broken down and the calcium lining the boilers internal walls have been sealing the boiler from leaking. Upon cleaning the boiler , calcium is removed and the seals don't hold and you know the rest. I have personally given a machine to a family member and told them never to descale just to see what happens ( will the boiler go , or water stop flowing due to blockages? ) I can honestly tell you that this machine was made in 1996 and I had replaced the boiler 8 years ago , to this day the machine has not missed a beat and no leaks on boiler ( I have instructed them to regulary clean out brewer and lubricate seals ). Ah they hardley use it I hear you say , quite the contrary , Italian family, machine used every day and even taken once in a while to their local social gatherings making coffees for over 30 people. I also have a customer who every so often after 2 years will come back for a new boiler fitted ( machine used in pannel beating shop ) I told him to try not doing any descaling until he could see any water flow restrictions. It's been over 3 years now and I havent seen the machine back yet but I do time to time come across him and ask how the Saeco is going , he says "all is well". Now not doing a descale at all is madness as I have had many blocked or semi clogged boilers due to high calcium deposits ( expecially around the beach coast areas ) But if you feel that your machine is pumping a little less water and the brewer is clean from any blockages then a well deserved descale is probably needed. With older machines you only need to reset the descale light or display if not needed. With other types like Saeco Incanto you need to only go through the descale process without the additive or cleaning fluid introduced into the water tank and decsale will reset.I hope I have shed some light on this issue and I'm not trying to say Saeco are pulling the wool over your eyes when it comes to descaling. I am going by my experiences only and what I have seen during my time with these machines. Enjoy your Coffee
Posted on Apr 05, 2010
  • 234 Answers
It is always best to use what is recommended by the manufacturer but it is also possible to use vinegar. Vinegar is much harder to get out after you use it, however and will taste bad if you do not get it all out.
Citric acid is a better choice.
I would really try the solution that the espresso machine manufacturer suggests, however.
Posted on Apr 17, 2009
Error code 5 on saeco minuto coffee machine
Error code 5 means the water flow is obstructed. Here are possible locations:
1- The machine was not descaled. Calcium deposits are clogging the water system.
2- The flow meter is not passing impulses for water flow speed & quantity.
3- Descale Descale Descale.
Before you select the automatic descaling, make a few espresso without adding coffee grounds. The automatic cycle does not clean the coffee side of the machine. You have to do it intentionally.
Dec 18, 2016 | Saeco Coffee Makers & Espresso Machines
Tip
How to descale espresso machines.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Here is a basic generic picture of a espresso system of how they work.
I hope this helps. Feel to contact me for addition questions. Thanks Mike
on Jul 26, 2011 | Coffee Makers & Espresso Machines
Descaling light flushing & nothing else works following descaling.
probably you have to rinse the machine and then it will be work!
Dec 28, 2014 | Saeco Coffee Makers & Espresso Machines
Need a descaler
instractions are from manual HD7810/00
Use the correct descaling agent
Only citric acid-based descalers are suitable for descaling the SENSEO
machine. This
type of descaler descales the machine without damaging it. For the correct amount,
see under 'Descaling procedure' below. Each descaling mixture can be used only once.
After use, the descaling mixture is no longer active.
We advise you to use the special SENSEO
Descaler (HD7012/HD7011/HD7006).
Read the instructions on the package of the descaling agent.
Never use a descaling agent based on mineral acids such as sulphuric acid,
hydrochloric acid, sulphamic acid and acetic acid (e.g. vinegar). These descaling
agents may damage your SENSEO
coffee machine.
Descaling procedure
1 Mix 50 grams of citric acid with 1 litre of water in a measuring jug. Stir until
the powder is completely dissolved.
2 Fill the water reservoir up to the MAX indication with the descaler mixture.
Then put the water reservoir back into the coffee machine. (Fig. 3)
Note: Not all SENSEO
machine types have a water reservoir with a capacity of
1 litre. If you have a SENSEO
machine with a smaller water reservoir, repeat steps
2 to 6 with the remainder of the mixture without filling the water reservoir up to
the MAX indication.
3 Press on/off button 3. (Fig. 10)
The machine is ready for use when the indicator light lights up continuously.
4 Place the 1-cup holder h with a used coffee pod in it in the coffee machine.
Close the lid and make sure it is properly locked.
Note: Always put a used coffee pod in the pod holder when you descale the
machine. This pod serves as a 'filter' to prevent the sieve or hole in the pod holder
from getting clogged with scale residue.
5 Put a bowl with a capacity of at least 1500ml under the spout to collect the
descaling mixture (Fig. 8).
6 Press the 2-cup button hhand let the machine operate. Repeat this until
the water reservoir is empty. (Fig. 25)
Never interrupt the descaling process!
7 Repeat steps 1 to 6. Replace the used pod with another used pod to filter out
the scale residue.
Note: To descale properly, you have to use 2 litres of descaling mixture.
Never descale the SENSEO
coffee machine with the lid open. Make sure the lid is
properly locked.
8 Rinse the water reservoir with tap water. Fill the water reservoir up to the
MAX indication with tap water and repeat steps 3 to 6.
Note: Do not refill the water reservoir with used hot water or the used descaling
mixture.
9 Fill the water reservoir with fresh tap water up to the MAX indication again
and repeat steps 3 to 6 once more.
Note: Always rinse the machine by letting it empty two full water reservoirs.
10 Remove the used pad and clean the pod holder after descaling to prevent the
sieve or hole in the centre from getting clogged.
Mar 30, 2014 | Philips Senseo HD-7810 Coffee Maker
What is a miele cva 2650 descaling funnel
The descaling funnel is a small, dull red insert that replaces the capsule holder and is used during the descaling cycle. I purchased a used CVA2650 that came without the funnel. I called Miele concierge service for help. They stock the descaling funnel and sell it for $15.95. In my case, they simply mailed one at no charge without me even asking. Great customer service!
May 10, 2012 | Miele CVA2650 Stainless Steel Espresso...
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Jun 29, 2011 | Microwave Ovens
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
Hello , I got a present of a Saeco Royal Professional without an instruction booklet . The machine tells me it needs a descale . Can you please advise as to how . Many thanks , Sean Kavanagh
Hi
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the steam knob then open it again to rinse your machine. When its done exit the descale mode and go to the "Reset descale" just under it and enter. Choose "Yes" and push the enter button to accept. It will tell you when it needs to be descaled again.
If you want to make your machine last a long time, go to the water hardness in the menu and change your water hardness to the #4 and always push the enter button if you want to make your changes permanent. If you don't, no changes will be made and it will still be the same when you exit.
Jan 06, 2011 | Saeco Royal Professional Espresso Machine
Descaling a Saeco InCanto deluxe
Press and hold the descale button(lower right), it will light up.Then you can start the process. The machine will prompt the next step when the solution in the tank is used up. Have a go.
Apr 04, 2009 | Saeco INCANTO DELUXE Espresso Machine
Nespresso D300
Have you tried descaling it. This message displays when it's time to descale and I don't know of a way to turn it off without descaling it.
Aug 10, 2008 | Nespresso D300 Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
539 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
