Question about Mitsubishi VS-6041 60" Rear Projection Television
Vs 6041 This just happend last night, the screen goes black, you can hear ok and just see an outline of the picture, like the picture is being blacked out. We dont have the user manual or the remote for this TV. Its hooked up to comcast and we thought maybe that was the problem, but works fine on another TV. When we push the Vol up or done the picture returns to normal for just a few seconds then black again,thanks for any help you can provide
    Genius:
  • 1,139 Answers
Hello bgill,
At first I thought this was a problem with the bulb, but as I read further into your description of the problem the more it sounded like a control processor issue. The fact that the TV acts normal when the volume control is pressed, indicates that the control processor might be going bad, or at least some of the processor biasing circuitry might be going bad. The circuitry in question is somehow linked to either the bulb control circuitry.
You will have to have a qualified TV technician look at this set to determine what the problem is
I hope this helps,
Thank you,
Shuttle83.
Posted on May 31, 2008
SOURCE:
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Tv
OK this is going to be either a tube problem or a convergence board problem, either way your going to have to get it serviced, unless your really electric savy and care to take it apart and solder pieces. There is no real fix to your problem without actually going "in"...
Sep 17, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS 6041. Just began having problems
Replace Both of your STK ICs example STK394-250 they are big black ics will have part number on them Call Mats 1-800-628-1118 for parts.
Sep 16, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS-6041 60 in. doesn't power up
Hello Tremulant
This denotes a possible problem with the Low or high voltage power supplies. The clicking you here might be the shutdown circuit acting because of excessive draw of current. The problem will most likely be associated with the HV power supply, but you will have to have a qualified TV technician check your TV to make sure.
I hope this helps,
Thank you,
Shuttle83
May 31, 2008 | Mitsubishi VS-6041 60" Rear Projection...
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Mar 05, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Black box on screen
This happened to me and it turned out the closed captioning on my TV were activated somehow. I never even touch the controls on the TV but I had to manually check the settings on the TV and found that the captions were on.
Sep 16, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
