My amp protection light only comes on
WHEN THE AMP TURNS ON I JUST GET A PROTECTION LIGHT
  • 30 Answers
SOURCE: Amp keeps turning itself down - cant turn off 'protection'
yes,pls.stop plugging the system,you may harm your system if you do so,the system has it's own system analysis mode,and if there's something wrong in the circuitry,it will activate,you need the authorize service center my friend,it's a technical problem.
Posted on Feb 18, 2007
xtpfly
SOURCE: protection light on
go to power acoustiks website at: poweracoustik.com then tech support look at how to insatll an amp
Posted on Jun 29, 2007
  • 631 Answers
SOURCE: Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
Posted on Dec 31, 2007
  • 631 Answers
SOURCE: my amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Posted on Feb 28, 2008
Hazardsneon
  • 100 Answers
SOURCE: When powered on protection light comes on
Protection usually means that there is a short some where. If it is inside the amp or external I couldn't tell you. You could check the fuse to make sure that isn't blown. I had a Memphis amp that blew both fuses and the protection light came on. I swapped out the fuses and worked fine, still works. If you have a multimeter set it to OHMs and check the resistance between the power terminals. It should be very high. If these things don't work then there is most likely something wrong with the amp or your power termination. I wasn't able to find a lot of information on this amp but if it has screw type terminals, did you use terminals. If you just put the wires in the terminals make sure there wasn't loose strands touching. I hope you can get this one.
-Andrew Hawkins
Posted on Mar 29, 2008
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Amp turns on but no output
1 make sure its hocked up properly .2 see i if the protection comes on.. with out the speaker wires hocked up if it does the u have a bad amp.3 if the amp protection light is off with out the speaker being hocked up and after hocking up the speaker it comes on the u have bad wiring to your speaker or a bad speaker
Jun 14, 2013 | Jl Audio 500/1 Car Audio Amplifier
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
VR3 Amp Protection Light problem
Looks like you have covered all the basics.
The remote wire is the switch that turns the amp on and off. So you are probably just killing the power to the amp.
Sounds like a short in the amp itself if all the input and output wires are disconnected and the protection is still coming on.
Mar 25, 2009 | AudioBahn A4401Q Car Audio Amplifier
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Mar 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
358 people viewed this question
 Grubhead
Grubhead
