Question about SanDisk Sansa e250 MP3 Player
I cannot format my device and i do not know why. When im in the digital music store it shows that i have memory used but i deleted all of my data. When i try to put music into my device it says the track is not compatible with my device but my device takes mp3 tracks and i put mp3 tracks into it but it still tells me the same thing...please help!!!
  • chetos Sep 17, 2007
    yeah i tried formatting it through my computer but it just tells me that the format could not be completed
  • moniatia Jul 25, 2008
    i would love to put music on my sundisk e250
  • 150 Answers
Try it this way, the below was copyed from an earlier post of mine. Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Posted on Sep 17, 2007
Having problems purchasing selected music and transferring to my mpg3 using my pre-paid Best Digital Music Card.
Posted on May 10, 2008
How to change the time settings in sansa e250R
scrolling down to Settings and select
Date & Time...
after you select it..just change the date and time from there..
I hope that helps..
Please rate accordingly
Thank you
Should you need the device manual, please click on the link below...
Dec 16, 2008 | SanDisk Sansa e250 MP3 Player
E250r shows as e200 when I plug it in to renew.
Other solutions are in the above link, make sure u follow directions for 2xxR and not the 2xx..............
How to get rid of the "synchronize to continue music subscription" message if it just appears out of nowhere on your player- this fixed mine when it gave me that message:
delete the STORE.HDS file in the system/wmdrmpd directory of your sansa (optional)
import your protected songs into WMP, and resync your protected music (with WMP) in MTP mode
play a protected song and let it rebuild the store.hds file (you will experience severe lag for about 15 seconds as it rebuilds) and the music should play.
Sep 25, 2008 | SanDisk Sansa e250 MP3 Player
Can't delete music or load music on my sansa e250r 2.0
In your windows media you will see the device name have to make sure the device is under MTP mode..then click on the player and you will see all the can just right click on the songs and delete them..if you dont want the device to sync automatically you can click on sync and then click on the device name and click on sync setting..there you can modify if you want it to sync automatically..
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
May 15, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
Music DB??? clear 6 MB???
Have you tried re-formatting the device?  This will "wipe" memory, getting rid of corrupted files, etc. and should restore use.
Oct 24, 2007 | SanDisk Sansa e250 MP3 Player
Used memory i never used
With most MP3 players, some of the memory is used for system files and software. Just delete all the things you done use (i.e. pictures, playlists, Rhapsody Channels) and whatever space you have free is what you have to work with.
If you want more memory, I highly suggest a microSD card
Aug 12, 2007 | SanDisk Sansa e250 MP3 Player
I have read from other users that it it not correc to format the player using NTFS. If you can try remoformatting the player in fat or fat32.
Jul 09, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my Sansa Sandisk e250R
To fix it, format your Sansa. I had the exact problem. Plug it in, then in "My Computer" right click its icon and hit format. Do not select quick format. Then it will be fixed.
Apr 27, 2007 | SanDisk Sansa e250 MP3 Player
Finding the music to delete
Use Media Monkey instead, or change Windows Media Player's configuration, so that it sees more songs.
Jan 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
