Question about Dishwashers
Doesn't clean plates.
Connected up HEC9AFM slimline dishwasher, doesn't seem to clean dishes very well. Still have marks on the plates and streaky glasses. Also, cannot find the manual.
  • 423 Answers
Ross,
Try this before you decide your dishwasher is broken:
Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) and use it. Re-evaluate after 2 loads of dishes. If problems continue, keep using the brand name powder but also:
With a screw driver. remove the filter shroud beneath the lower spray arm as far as possible (take pictures as you go) and rinse everything, including anything that looks like a mesh filter. Also, inspect all wash arms for blockages of any holes and clean them.
With a flashlight, find and remove all debris (watch out for broken glass!) Inspect the impeller for problems or not being tightly secured. Reassemble.
Test out. If problems continue and your dishes have a film on them, suspect that you heating element has failed. Replacing it will work wonders!
If problems continue, the problem is most likely a failing wash pump motor. If you replace it, your on you way.
Posted on Apr 18, 2009
  • Jeff Meyer Apr 21, 2009
    Hi Ross,
    I am happy that things are working for you now. Do you have time to post back here what the problem was and what you did to repair?
    Thanks!
The lg dishwasher doesn't use all of the detergent and the dishes are not 100% clean
first check the water supply if good water pressure.then check the pump under the bottom dish tray remove parts check for debree.
Jan 25, 2013 | Dishwashers
How to clean the strainer of a Kenmore 665.1348 dishwasher
Try following this YouTube video titled: Dishwasher DIY maintenance Kenmore dish washer.
https://youtu.be/BRGee1nRjO4
Please let me know if I was able to point you in the right direction.
Dec 14, 2017 | Kenmore Dishwashers
I've had the heater element replaced, but the water still is not getting hot.
If the heating element is fine then the problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 13, 2011 | LG LDF6810 Built-in Dishwasher
We have a 4 year old dishwasher.It is not washing as good as it should.The machine seems to rinsing the dishes etc in soiled water.I've checked the syphon and it doesn't appear to be blocked.I...
Hi wesalado,
Please follow my Tip below on some hints on how to keep your Dishwasher in tip-top shape:
DISHWASHER NOT CLEANING PROPERLY ANYMORE...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Zanussi Dishwashers
I have a GE quiet/power2 MOD D5560LOOSS It doesn't release the soap from the dish. It wasn't cleaning dishes well and then it completly stopped. I have tried different settings. It sounds as if...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 13, 2011 | GE Dishwashers
Frigdaire Quiet II - Dishes in upper portion are not coming clean
My dishes are not all clean when done washing. Also it doesn,t sound like the not a lot of pressure when washing like it did when it was newer.
Jun 30, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwashers Logo
225 people viewed this question
Top Dishwashers Experts
