LG home theatre system model LH-T1000
Hi trying to run this system on a lg 42pc1dv flat screen tv and its sayin no signal but i have sound... please help me...
  • ren2022 Sep 17, 2007
    thank you
Hi i've got a vs2000cd and a vga card doineed the version 2 software to make it work if so where do you get it many thanks
Posted on Jan 27, 2008
  • 65 Answers
Hi I have the same tv. How is the video signal coming out of the dvd player and what is it plugged into on the tv. I travel for a living and coach my wife over the phone all the time.
Posted on Sep 17, 2007
  • G Smyth Apr 04, 2013
    Hi Dan, I have connected the sound sytem to the tv via a scart cable. The surround system plays dvd no problem and the sound comesthrough the system perfectly. I just can't get the sound from the TV to come through the surround system.
SOURCE:
Ch 9 picture froizen.has sound.cannot change
U have cable,some kind of pay tv?Tries unplug the cable box,replug the box for reset or to update new solfware for the box.If u have free air tv,get better antena like out side door antena or a digital antena.Also should change the batteries in ur remote and clean the IR lights both remote and tv make sure no blocking path to signal.
Oct 31, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Frozen screen , has sound,remote does not work, turns off and on
The 42PC1DV has a freeze screen function. Looks like you may have accidently switched it on .....check your tv manual on how to switch it off.
Sep 26, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Lost picture on my LG 42" plasma model number 42PC1DV
it is problem high voltage unite problem (EHT) change it then solve your problem
Sep 03, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
Sound to mute
i would suggest turning off the system, disconneting it from the outlet and plugging it back in, the should reset the settings, please post with what you try to do.
Thanks and i look forward to your post.
Nov 13, 2008 | Audio Players & Recorders
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
Flemflam-   There is a couple of options here. If you are using a DirecTV Receiver or a box from the cable company then you want to run the Audio out lines to your Audio/Surround Sound Receiver. If you are running cable directly into the TV then you want to use the Audio Out Plugs on the TV. In some cases there is no Audio out but there is a Headphones out. In this case you can run a Mini-Plug to Composite Audio cable to the receiver.    You can also Call 1-800-GeekSquad and they will dispatch an Home Theater Installer to resolve your problem! They are great for Turn Key Solutions!
Jul 11, 2008 | Insignia LCDTV26 26 in. Television
Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
Apr 21, 2008 | LG Audio Players & Recorders
Resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Jan 20, 2008 | LG LH-D6230 System
There sould be audio outputs on the back of it, and the manual should clearly show how to set up a home theatre with an external sound system and all.
I don't know what kind of sound system you have, but I think it might be best to connect your video source (typically DVD player) to your sound system, as it usually can be done better that way. No need to introduce another link in the chain (your TV) that could degrade sound. Also any external tuner could (should) be connected to your sound system directly.
If you use the internal tuner in your TV to watch TV the audio out is your option. Best way to get this right is to consult the manual. They usually have some diagrams that shows a few options of how to do it.
Dec 05, 2007 | LG 42LC2D 42 in. LCD HDTV
497 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
