SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
SOURCE: Frigidaire Affinity front loading washer will not spin
send me an e mail at [email protected] for futher info
SOURCE: Front loader will not spin
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
SOURCE: won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
