Question about Philips 60PP9753 60" Rear Projection Television
Bulb Replacement I have a Philips 60PP9202 Rear Projection HDTV and a problem with the red bulb. After removing the screen and looking at the 3 bulbs (Blue, Green, and Red), The red bulb is flashing like a strobe light. The other two bulbs look fine. Is this repairable? Where can I get a new red bulb? How do you replace it? Thanks!
  • pmccarty12 Apr 17, 2009
    Thank you! yes, they do look like lemonade when it's turned off.
  • Philips Master
  • 3,459 Answers
Check the site www.TvRepairKits.com for a repalcement tube
Posted on May 07, 2009
  • 87 Answers
It might be the the socket board on this model not the crt tube. Closely look at each tube these tubes end up contaminated. They start looking like lemonade inside. Usually the blue and green, with the tv off see if the green and blue are as clear as the red with a flashlight. You might want to call a service center. Cheaper in the long run over the cost of a tube.
Posted on Apr 17, 2009
  • Terry Riegel Apr 20, 2009
    THE TUBES ARE BAD THE FLUID NEEDS REPLACED MAY NOT BE WORTH IT.
Red bulb is out
go to tvrepairkits.com.easy to change but expensive.
Feb 19, 2013 | Philips 60PP9202 60" Rear Projection...
The power will not turn on and the power LED is flashing red.
PT-50LD54 is an LCD rear projection TV with a consumable bulb that wears out normally after 2-5 years of use.
Most likely you need a bulb. That is first step in any troubleshooting for that tv. Check out Panasonic Gallery to identify lamp and replacement bulb.
Changing bulb involves removing the lamp assembly and replacing the bulb in the lamp assembly. Like doing a puzzle. Requires philips screwdriver, pliers and patience. Don't have jam on your fingers when you do it.
easyab
Apr 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
I want to replace the bulbs in my 60PP9202/17F but i cant find a place to buy them from. What type of bulbs(CRT, DLP, etc..) and where do I buy them?
You will need CRTs. There are three of them in your model Red, Green and Blue. You can get replacement CRTs from www.tvrepairworld.com that also have the CD with replacement instructions.
Mar 28, 2010 | Philips 60PP9202 60" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
Where do I open the set to replace the lamp
This is a CRT projection TV and does not have a bulb -it has three picture tubes (red, green and blue)
Sep 27, 2009 | Philips 60PP9202 60" Rear Projection...
Replacement lamp/bulb for a Philips 51PW9303
Call Encompass electronics 1-800-638-3328 also part # is on Tube you have a RED/GREEN/Blue each tube has part number on it.UNless you have DLP TV then it would be a Lamp.
Sep 19, 2009 | Philips 51PW9303 51" Rear Projection...
Projector tv the red and green colors are not in sync
no its a convergence tube problem u shud change the green tube.
its the exausted one in this case.
Mar 15, 2009 | Philips 60PP9202 60" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Philips HDTV wont turn on
If your model number is 60PP9202 you dont have a bulb, you have three CRT picture tubes instead, and if the power light doesnt come on check the fuse on the power board. Remove the rear cover after unplugging the cord and look at the small board on the irght where the power cord attaches you will see a fuse its most likely blown.
Jun 27, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9753 60" Rear Projection Television Logo
213 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
