Question about Logitech X-530 Computer Speakers
Have no sound at all
Pc crashed ,rebooted now no sound from speakers. click power on u can hear it kick
    Problem Solver:
  • 7 Answers
No system restore would not work since you reinstalled windows..you have to install the drivers for your soundcard, if you're using the motherboard then it must be some settings that you got to change..
Posted on Apr 18, 2009
  • 298 Answers
You can try a quick restore its in the program files>accessories>system tools "restore" just choose restore my computer to an earlier time and choose the time that it was working best.
Posted on Apr 17, 2009
  • Mike  Petrowsky
    Mike Petrowsky Apr 19, 2009
    Rebooting is not the same as reinstalling windows. Get your terminology right. If my pc crashes I would reboot it also, no format and reinstall windows. thats a Last resort.
    again reboot= To power off and cycle power back on,
PXE-E61: MEDIA TEST FAILuRE, CHECK CABLE PXE-M0F: EXITING NVIDIA BOOT AGENT. REBOOT AND SELECT PROPER BOOT DEVICE
Hope this helps. I assume cable is good, try to listen by drawing your ear nearer to the disk. The normal sound of the harddisk as the disk spindle comes to work when given power, a uniform thin sound of rotating motor. The abnormal rotations sounds like initializing motor-kicking and died down in cycle or it gives audible clicking sound due to arm-head drive coil initialization failure, it may also give a scratching sound when the tiny head crashed against the disk. By then, this audible signs gives us hint that the harddisk has a fatal error. However you can try another good cable, attaching it to another sata port, power connector and trying it to run on another pc. Hope it gives good signs that your disk is alive.
Mar 08, 2014 | Seagate Technology Barracuda 720012...
Pc keeps crashing during online gaming
This sounds like either a case of graphical artifacting, or your pc is simply crashing.
Graphical artifacts are things not normally seen on your monitor created by overuse of the graphics card, such things as white pigments and the odd pixel patterns you saw are some signs of this. I've experienced this problem, and have had the speakers make the noise you heard noise upon restarting the pc. To see if this is the cause I would try running an extremely graphically intensive game or program such as a 3D benchmark to test the limits of the graphics card, and if you see the odd pixelation during the testing, then it is most likely that the card is the problem, and you should call its manufacturer for a replacement.
If your pc is simply crashing then either your power supply is not putting out enough power for you graphics card, or the graphics card is not hooked up to the motherboard properly. The first to do to check if this is the case is to run your pc until it crashes and see how hot your pc has gotten, if it is very hot, then your power supply could be overloaded, or you may not have enough airflow in the case. I would suggest opening your pc and looking for anything out of place, and even perhaps getting professional help from a technology store.
Oct 12, 2012 | XFX AMD Radeon HD 6770 Graphics Card...
No sound on dell dimension 4700c
There can be more than one reason, why the computer can't play any sounds. These are discussed below:
If you have a desktop computer, it may or may not have a separate sound card. But in case of laptops, the sound card is integrated into the motherboard and cannot be removed, so some of the solutions may not apply to laptops. Also, new laptops come with built-in speakers, so the external speakers and cabling problems may not apply here, unless you use external speakers or headphones.
So, where do you start, when you can’t hear any sounds from your computer?
Before we start with the solutions, did you try the simplest solution first? Rebooting or restarting the computer is the simplest solution and should be tried first. If you didn’t already reboot, try it now. The sounds may just work after a reboot.
Can you hear the Windows startup sounds from the computer? If you can hear the Windows startup sounds, the sound card is working fine. If you can’t hear any startup sounds, enable the System Sounds in the Control Panel, if they are disabled. If you aren’t able to enable the system sounds and they are grayed out, you may need to install the sound driver.
Are you trying to play an audio CD, and not getting any sound? If you can hear the System Sounds, but can’t hear anything from the audio CD, even though your audio player software tells that it’s playing the disc, the problem is most likely with the digital cable that goes from the CD/DVD driver to the sound card (or to the motherboard).
One side of this cable goes into the back of the CD/DVD drive and the other goes into the sound card or on to the motherboard (in case of motherboards with built-in sound).
Are the speakers connected to the proper sound port / jack, at the back of the computer? Are they powered ON? External speakers generally have a separate power adapter, which plugs into the wall socket or any other power source. Is the speaker volume control, set to a comfortable level? If not, turn it to the middle position.
If in doubt, test your speakers by connecting them to another sound device like CD/DVD player or a radio/tape player, or any sound source. If you can hear sounds from the speakers, they are fine.
Check that the speaker pin is connected to the green jack on the back of the computer. Also, check that the sound (check speaker icon in the system tray) isn’t muted. Such a simple thing, which can happen accidentally, can confuse some people when they can’t hear sounds from their computers. This can get overlooked because the speaker icon may be lost between many other icons. Click it and un-mute the sound, if it’s muted.
Note: If you can’t see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click “Sound and Audio Devices” and check the box that says “Place volume icon in the taskbar” and click OK.
Try plugging in a pair of headphones in place of the speakers, to check whether you can hear anything. Play a song or music CD or any sound file, which you may have on the computer. If you don’t have one handy, you can run a command to test your sound:
Click the Start button, and then click Run (or Search, in Windows 7 / Vista). Type the following command and then press the Enter key: dxdiag
Click on the ‘Sound’ tab to see the details of your sound card. You can also test your sound card from this tab. Note the name of the sound card and the manufacturer, on a piece of paper.
If you can’t see the name of the sound driver, or aren’t able to hear the sound by using the ‘Test DirectSound’ button, or you get an error, the problem may be with the sound driver. If the sound worked sometime ago and now it isn’t working for some reason, the simplest solution for re-installing the sound driver is to do a System Restore. Restore the system to a date that you know, when your sound worked. Check out the following links for a short tutorial on System Restore
Note: Current documents, files and e-mail are not affected by System Restore. If you get an error like “Restoration Incomplete. Your computer cannot be restored“, undo the last action by selecting “Undo my last restoration”.
Here’s a youtube video on how to restore a system with System Restore: http://www.youtube.com/watch?v=mU5yqvye57E
Here are step-by-step tutorials on System Restore:
For Windows XP:
http://www.howtogeek.com/howto/windows/using-system-restore-in-xp/
http://www.5starsupport.com/faq/xp-system-restore.htm
For Windows 7 or Vista:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
http://www.vistax64.com/tutorials/76905-system-restore-how.html
For more information about System Restore, visit the following links:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
http://support.microsoft.com/kb/306084http://en.wikipedia.org/wiki/System_Restore
http://windows.microsoft.com/en-US/windows-vista/System-Restore-frequently-asked-questions
If System Restore didn’t help or you get a message that System Restore couldn’t be completed, try the following:
Start the Device Manager (Start -> Run -> devmgmt.msc and hit the Enter key). In Device Manager, Click the + sign next to “Sound, video and game controllers”. See that the sound driver that you noted from dxdiag above, is listed.
Doube-click this sound driver. Device Manager should give a status message that the driver is working fine. If the driver isn’t there or if it shows a yellow exclamation mark, shows under other devices, or gives any other kind of status message, reinstall the driver. In any case, it doesn’t harm to uninstall and reinstall the driver.
From this sound driver properties page, you may also click the Troubleshoot button, to open the Sound Troubleshooter in the Windows Help and Support Center.
You can also visit the following link about tips for fixing common sound problems:
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-sound-problems
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 03, 2010 | Dell Dimension 4700C PC Desktop
No sound from my pc speakers
You don't have the drivers loaded for your motherboard. Go to the home page of the company that makes your system then go to the DRIVERS section. Find your make and model and download and install the drivers. You may have to reboot your system for the drivers to kick in.
Mar 16, 2009 | E-Machines (T2958) PC Desktop
Sudden sound crash in my pc. I installed sound driver from my asus motherboard cd. but always showing that driver not found reboot your system and setup this again
Boot the system and Press F8 and select the Lask Known Good Windos XP and check if you are able to hear the sound , If no then reintsltall the driver,.
Jan 11, 2009 | Computers & Internet
Kenwood vr 615 speaker sound cuts out
it means there is some shorting in the speakers.. check for the shorting
Dec 14, 2008 | Audio Players & Recorders
Usb speakers
You need to install the sound card drivers for your PC, check the cds / software that cvame with your PC, or go online to PC manufacturer's site to download drivers for your system.
Apr 27, 2008 | Audio Players & Recorders
Logitech X-530 Computer Speakers Logo
126 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
