Question about EA - Electronic Arts Mercenaries 2: World in Flames for Xbox 360
I cant verify an hvt cos he's dead in the water, help please
I blew up an oil rig, and now an HVT is in the water dead is there any way i can still verify him, even though he's in the sea?
  • 1 more comment
  • alex_newton Apr 18, 2009
    The problem is... i don't have an earlier save
  • alex_newton Apr 21, 2009
    autosaved afterwards
    i sunk, which kinda dont help things, and its under the oil rig i destroyed
  • 3 Answers
I don't think you can verify him in the water but im not sure if you can get a boat and push him to a near by beach. What you should try to do is reload your most recent save before the incident so that you can retry the HVT.
Posted on Apr 18, 2009
  • 1 more comment
  • Casey Harris Apr 20, 2009
    Don't you have an autosave before you killed the HVT or did it autosave after you killed him?
  • Casey Harris Apr 21, 2009
    That really sucks. Can you see his body floating or did it sink?
  • Casey Harris Apr 22, 2009
    Well it dosnt sound like your gonna get that HVT so all i can say is just forget about it or if you want to get all the HVTs that badly I would say you have to start the game over but anyways good luck hope it all ends well :)
My canon ir 2520 has a insert the drum error
hi. remove the drum unit from the machine and verify the contact in the back side of the unit . maybe is dirty . if problem persist you need to try another drum . if problem peristaltic after that maybe there is damage in the hvt electronic board
Apr 25, 2017 | Canon Office Equipment & Supplies
Cooling fan is not coming on. no temp light though
Is the engine even overheating? Suzuki V-Twins are notorious for running cool. If the fan motor is working (test by sending power through the leads) then test across the temperature sending switch with an ohmmeter. First measure the resistance cold. Then run the engine until it's completely warmed up and measure again. IT should read a different resistance, +/- 300 ohms. If there's no difference the best way to verify after that would be to set up a rig to hold the switch in a pot of boiling water; it should definitely read a difference at 212 degrees. Of course, with any 18 year old mechanical device your mileage will vary.
Jun 01, 2015 | 1997 Suzuki VS 800 Intruder
What type of oil do I use in a elantra 2.0 hvt 2005 model
the oil type should be printed on the oil filler cap , most likely to dirty to see so give it a wipe , if not there check the owners manual
Feb 23, 2015 | Cars & Trucks
Canon copier ir2016 and the print page is white or no image just blank page displayed
Sir
Pl. check the drum unit contact points up HVT card. Replace HVT card. (Assumed you have good drum unit). Check the toner throw at developer mag roller.
Thanks.
Dec 18, 2014 | Canon Office Equipment & Supplies
Had a water pump leaking , last night while driving it got real hot even though i was keeping antifreeze ion it all the time, plus my oil light came on while the gauge said was reading the hot the whole...
Pop noise I fear was a cooling system hose or radiator blowing out. I would say cylinder head is now bent gasket leaking and combustion into cooling system . a preasure test of each cylinder at TDC firing will verify this and specificly locate the main area of concern. Red lights on dash are the same as street lights red means stop or pay the consequences
Dec 10, 2012 | Cars & Trucks
Error 51.23 hp laserjet pro cm1415fn color mfp
make sure hvt flat cable connected properly (dc board to hvt)
Nov 15, 2012 | Office Equipment & Supplies
Dear Team, My samsung microwave oven is not working as per engineer its HVT is not working .pls confim what is the remedies. and cost for HVT... regards
The remedy is to change it to a good one as it can cause more damage to your microwave... the cost of one high voltage fransformer is about 90.00 and the cost of repair can be from 100.00 to 200.00...its best you buy a new microwave as the damage might lead from one problem to the next..good luck.
Sep 13, 2011 | Samsung SMH7178STD Microwave Oven
My car broke down a little while ago and the breakdown service said it was the head gasket that blew but I don't believe it since the battery light shows in the car so i believe it must be the battery that...
Pull the oil dipstick, if the oil appears white or like mayonaiseor mud or anyother version of an oil/water emulsion, your head gasket blew. Don't try to run your motor. it will only get more expensive.
Feb 17, 2011 | Fiat 500 Cars & Trucks
How can i fix the error code C970 on my toshiba e-studio 230?
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Nov 01, 2010 | Toshiba e-Studio 350 Copier
EA - Electronic Arts Mercenaries 2: World in Flames for Xbox 360 Logo
148 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
