They have a bridge switch on the rear.you cut the switch on and use one neg on one channel and the positive on the other.it shows which ones on the rear of the 500t.
I do not believe that those amplifiers have built in bridging circuits. It is still possible to bridge the amplifier by taking one of the input signals, branching it out with a Y cable, and inverting the phase of the signal by 180 degrees. This can be done with an inverting operational amplifier circuit and you may be able to find a device that does such. If you feed an inverted and non inverted signal into each of the inputs, you should be able to use both of the positive terminals on the amplifier and have a bridged amplifier. You still must remember that impedance loads will change and if your speakers are 4 ohms or less, I do not reccomend this. Hope this helps.
