Question about Brother Office Equipment & Supplies
Laminator blade apparently fell off
Little plastic yellow and black piece got knocked out of the right front part of the laminator. It looks like it might contain a cutting blade. I haven't yet been able to see where to put it back. Any ideas? Thanks, Ann
My boss figured out how to go on the Brother web site and pull up a picture. The he was able to snap the piece back in place.
Thanks for asking.
Ann
Posted on Apr 20, 2009
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Jun 26, 2012 | Gbc HeatSeal H425 Laminator
How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Jul 31, 2010 | Stanley Utility Knife
Oster Power Pro Cordless Clippers I took the blade off, sm. long black plastic piece fell off. Wanted to change blade to ceramic. Can't get it back together don't know where black piece goes. Don't know...
The plastic piece is a blade guide and has a slot down the length of it which the spring locates into. Simply slide the replacement ceramic cutter under the spring
Sep 29, 2009 | Oster 76076-010 Hair Trimmer
Putting on wind shield wipe for a nissian maxima 97
in the center of the wiper there is a little plastic, black piece. turn the wiper blade so that blade and the wiper arm make a "T". there is a tab on that black plastic piece that you have to push in, and at the same time you have to push the wiper blade down. easy
Jun 19, 2009 | 1997 Nissan Maxima
Broken choke conrtol
Yes. I had the same thing happen. Ryobi can send you that exact part. I know this for a fact, because I just got mine in the mail yesterday.
Call Ryobi at 1-800-860-4050. I'm sorry, i don't have the part number, I'm at work. I'll look for it when I get home.
What you do is take off the air filter casing (both pieces, front and back) and you'll see the yellow plastic rod going through the carb, with a little circular metal piece to adjust the air mixture. Get a pliers and pull out that metal piece (don't worry about ruining the yellow plastic rod, because it's already broke). Once you have that out, the yellow rod will slide right out. Once you get the new one, you slide it in, push the metal piece back on, and it's finished.
Side note: I'm not sure at what point I did this, but be careful. You do NOT have to take the carb off when you do this. If you do, you might do as I did and lose the spring and ball bearing that make the choke control click into the A, B, and C positions.
Fortunately, I just talked with a great guy in the Ryobi Service department and he's sending me those two peices free of charge.
May 28, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Head of philips norelco speed xl fell apart.
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Dec 20, 2008 | Philips Norelco 8175XL Electric Shaver
Replacing Heads for 8140XL Norelco shaver
Hope this helps!
Dec 02, 2008 | Norelco 8170XLCC Electric Shaver
IP4300canon printer
The problem is that the ridiculously cheap little plastic piece on the door hinge that is supposed to trip the switch that tells the printer that the door is open is either a) broken off or b) no longer aligned so that it pushes the switch all the way. I solved the problem by removing the top cover and gluing the switch open with super glue.
To open the cover, find yourself a small, flat piece of metal (or stiff plastic) about 1/2" wide and a few millimeters thick. (A very flat-bladed screwdriver will do, but I made myself one out of the non-sharp side of a straight-edge razor blade.) Push this into the 5 slots marked with an arrow around the sides and back of the printer (they're toward the bottom of the sides.) Pry up on the cover at the back and then pull straight up on the front. There are two flat vertical pieces that slide into slots at the front that have to come up - they were tough to make come loose, just try not to break them off.
Pick up the electronic control panel that is on the front right of the printer. (You might have to remove the silver piece of plastic at the right front corner. It pulls straight up to remove.) The switch is the little black plastic piece on the left side of the electronic control panel. Push it to the "open" position (opposite the resting position) and glue it in place. Reassemble your printer and voila! no more annoying "door closed" message!
Jan 10, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
60 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
