Question about Toshiba 42H81 42" Rear Projection Television
Is it the TV (Samsung DLP) or Comcast
I have been going back and forth with Comcast and reception issues. We had no problems at first when we upgraded from Basic Plus to Digital Service and installed the cablecard. About 2 weeks later, some of the HD channels would get "Weak or Scrambled Signal", and soon others would have a picture but "tiling" or pixelation. It eventually gets so bad, that it effects the analog channels as well, and I wind up with a green screen. After a number of different things (rebooting the tv by unplugging and replugging), Comcast trying to boost signal, we get a nice clean picture on all channels, so it looks like the problem is solved. But, eventually (anywhere from 2 weeks later to as soon as the next day) we starting having reception problems again. Comcast sent out techs yesterday. They checked the signal strength, and wound up changing some things out both inside and outside the house, including replacing some wiring that was coroded. After doing all that, it did not solve the problem. So, later on they came back and tried getting rid of the cablecard and going with the converter box. That did not work either. They determined it was not them, but my TV since they showed me that they could plug this old 13" tv into my cable system and the Analog channels were coming through fine. Here is where it get weird. We left the tv on when we went out, and came home a few hours later. Tiling was gone on the staion that we left it on (Local HD channel) and when he starting to look at other stations, our analog stations had come back, no green screen whatsoever. I don't know if the problem is solved, or if it is just temporary again. Anyway, the TV is a Samsung HL-R4667W, bought in 12/05 and is used mainly in the evenings (so low hours). DVD, XBox, and VCR never had an issue, and prior to going to Comcast Digital (just using Comcast Basic Plus Service), no issues with broadcast or Cable TV (no tiling/pixelation or green screens).
  • x408 Apr 17, 2009
    Woops - sorry, I posted this in the wrong place. My bad.
Never mind, posted in correct spot
Posted on Apr 18, 2009
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4663W DLP 46' tv: Just replaced with new color wheel and the lamp is newer -6months old. When I plug in the hdmi cable, I get picture but no sound. However, if I plug in the coax, I get...
You still need to get an audio Left and right connected from the video source.And for the digital reception from the antenna source is not possible because your unit is not equipped with a digital tuner(it is NTSC or analog reception only)it needs an add on digital tuner that has an hdmi output.Newer ones now are equipped with digital tuners.
Oct 27, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLS5679WX/XAA DLP TV set. Problem when I turn on the TV switch, lid on the LCD & Standby lamps back & forth, instead of turning on the screen.
Check for a defective lamp. Open the access door where the lamp is, remove it and see if visually it looks defective.
Sep 08, 2010 | Samsung Televison & Video
Is it the TV or Comcast?
I'VE SEEN QUIT A FEW SAMSUNGS DO THIS AND THE DIGITAL BOARD IS THE PROBLEM YOUR MODEL NUMBER DOES NOT HAVE A DASH HLR4667W AND YOU NEED YOUR VERSION NUMBER AND MAYBE THE BEST THING IS GET THE PART NUMBER OFF THE BOARD.
Apr 17, 2009 | Samsung HL-R4667W Rear Projection...
TV screen is fuzzy
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
This issue means that your xbox 360 console is having a problem with its Video Card.
Mar 28, 2009 | Microsoft Xbox 360 Elite Console - Black
Samsung HLP4663wx/xAA 42in DLP
Once you find the codes for the Samsung enter a 1 then the codes listed. So if you code was 2342 enter it 12342
Feb 24, 2009 | Samsung LN32A330 32 in. LCD TV
MY Samsung DLP TV Has Green/Purple Lines
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 08, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba 42H81 42" Rear Projection Television Logo
324 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
