How do I turn off the SAP - there is audio description of what's happening on NCIS which was not there before.
There is audio description of what's happening on NCIS which was not there before
  • nebrown Apr 18, 2009
    Problem is I do not have the remote that goes with the TV set so I cannot access the set's menu . . only Bell ExpressVu menu and it does not have an SAP setting.
    I was hoping there was another solution than needing the remote that goes with the TV.
    President:
  • 2,992 Answers
If the remote control has a SAP button, pressing it should cycle through the choices. Keep pressing it until you reach OFF. (That's probably how it got turned on. It's easy to hit a button and not know it.) If the remote doesn't have SAP button, adjust the settings through the set's setup menu. If you are using a cable box, make sure it doesn't have a SAP setting that has gotten turned on.
Posted on Apr 17, 2009
What is the SAPFeature on my tv?
How to Turn off SAP ' Techwalla.com
https://www.techwalla.com/articles/how-to-turn-off-sapMar 31, 2015 - "SAP" stands for Secondary Audio Programming. It is a feature several TV shows include for their non-English-speaking audience. SAP is essentially a second audio stream included with your TV show that lets you listen to the show in a language other than the original.
What is the SAPFeature on my tv Google Search
Mar 14, 2018 | Televison & Video
Matchline III 30. how do I turn off audio description?
The second audio program (SAP) is enabled/disabled as part of the initial set up procedure. Return to initial set up to disable SAP.
Nov 07, 2015 | Philips Televison & Video
Sony bravia troubleshooting
What you are referring to is the second audio program (SAP) which is enabled during initial set up of your TV. You can return to the set up procedure and turn off SAP.
Jul 16, 2014 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
There is something on some channels that is describing verbally what is happening on screen and we can't find out how to turn it off
Just look at the remote and find a button that is labeled MTS, SAP or Audio. Press this button one time and a display on your TV will show you the audio that your set is tuned to, (i.e., English or Spanish). If it shows AUDIO 2 or Spanish, press the button again until it displays AUDIO 1 or English then press ENTER or OK. With that, the audio should be correct.
Read more: http://www.kmbc.com/Descriptive-Audio-and-SAP-Audio-on-KMBC-TV-and-KCWE-TV/-/11664900/16438214/-/hay9otz/-/index.html#ixzz2eY64CP1f
Sep 09, 2013 | Televison & Video
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
What is sap and how do you turn it off
SAP is an alternate audio program usually seen in markets with different languages. The most common is for a Spanish broadcast of an English program. It is also used to provide audio descriptions of programming for the blind. There should be a menu option under Audio to turn this on and off.
Dan
Mar 03, 2010 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Background voice, 27 inch "truflat" 2005 model
What you're hearing is the descriptive audio track included on many DVDs for vision-impaired viewers. Does this happen when you're watching regular TV or just with DVDs? If it happens with regular TV, do you have a cable box?
Regular broadcasting sometimes uses SAP (second audio program) to send additional audio, and this descriptive audio may be the SAP channel on some programs. Check your TV's audio settings to make sure you don't have SAP turned on. There may also be settings for SAP in your cable box as well, so check there too.
When playing a DVD, descriptive audio is usually an alternate audio track. Check your DVD player setting to make sure you've selected normal audio for playback.
Apr 04, 2009 | RCA TruFlat 27F520T 27" TV
WE HAVE YOUR DVD-4600. MOST OF THE TIME THINGS WORK NORMALLY. WHEN WE RECORD A PARTICULAR PROGRAM ( IT HAPPENS TO BE NCIS) WE GET THE VOICE-OVER THAT DESCRIBES ONSCREEN ACTION FOR PERSONS WHO ARE UNABLE...
SAP is the "alternate program" that is broadcast by some stations and with some programs for the blind or for different languages as you have seen. Your DVD-4600 is set to receive SAP by default for some reason. There should be a setting to disable it. Or, depending upon how you have set up the recorder, your TV might be set for SAP. Check that as well to disable the SAP setting.
Dan
May 28, 2008 | Samsung Televison & Video
Descripticve Dialog on SAP?
Sony usually has a button on remote....MTS maybe....push =
cycles....Main...SAP....Mono.....
SAP = second audio program...........................T.
Dec 03, 2007 | Sony KV-36XBR450 36" TV
Televison & Video Logo
4,506 people viewed this question
Top Televison & Video Experts
