Question about Frigidaire FRS26ZSG
I Have a FRS22ZRGD1 Double door fridge freezer combo , the ice does not get any water . I have water to door to fill glass. I replaced water filter a pure souce type. I replaced solinoid valve still no water. Ice maker runs its cycle but no water
For all of you having problem of not getting any water to ice maker the water line running from solinoid valve to ice maker , mine was plugged solid with ice- try blowing through it once you have line removed from solinoid valve. I know they say you can removed the ice with a blow dryer but I tried that the ice was too far down to melt it .I took the line loose from the back of the fridge and un attached retaining screw and pulled plastic insert through cavity of fridge and ran hot water through it. Now it works fine.
Posted on Apr 18, 2009
Water dispenser in door does not dispense
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
http://www.amazon.com/LG-Electronics-MJX41178908-Refrigerator-Water/dp/B00AUDAJ0I
Oct 25, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Not making ice after changing filter.
Hi and welcome to FixYa I am Kelly.
A new filter can take several cycles of the ice maker to fill the filter up with water before. The average filter is around 30 oz and the average ice maker fill cycle is 3.2 oz. The new filter did not have any water in it. The water in the door has a resercoir so the air in the filter will still make the water work until you get air. Drain abour 3 tall glasses from the water in door. The ice maker should then work properly. The filter filters water for water in door (inside) and the ice maker so if you have water inside the door you should have ice UNLESS one of the inlet water valve solenoids has failed. Also make sure the Freezer door / light switch functions properly. The door switch is supposed to stop water and ice functions with the door open.
I would like to know if it starts making ice.
Thanks for choosing FixYa,
Kelly
Jul 26, 2011 | Jenn-Air JFC2089HE French Door...
Water overflows from icemaker & freezes in the freezer. Makes three ice cubes in a day & the water is extremely slow to fill glass from freezer door!
If both the water in door and ice maker are experienceing slow water problems the common point is the water supply itself.
This can be caused by:
1. Water supply shut off valve is partially closed or blocked with debris.
a. TURN water supply OFF
b. Remove the water line from the rear of the refrigerator ABOVE the in line filter (if one is installed)
c. Place the removed line into a bucket.
d. Turn on water supply and check flow. It should fill an 8 Oz glass in about 8 seconds.
If it passes this test then the water supply is fine. If it FAILS this test either cflear the obstruction in the line or replace the water supply valve from the house connection.
Test 2 (Water supply is OK
Reconnect water supply to external in-line filter (If installed) or water valve assy connection.
Your unit has a Verticle filter that if it is clogged will cause slow water flow.
Test water thru the door for the same amount of water flow. It should fill an 8 Oz glass in 10 seconds or less.
If it does ot do this then the VERTICAL internal water filter is clogged. (5 months or 500 Gallon change interval)
REPLACEMENT filter is PN LT500P but there are several like / suitable aftermarket replacements for the LT500P number.
As for the ice maker freezing up. There is only one cause for this and that is the water valve assy itself is bypassing water when it is supposed to be closed. The only remedy for this is to replace the water valve. They are not repairable.
The valve is available through sears parts direct:
http://www.searspartsdirect.com/partsdirect/part-number/LG-Parts/Refrigerator-Parts/5221JA2006D/0046/795/Model-LSC26905TT/3204/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=LSC26905TT&subCompDesc=Ice/water%20parts&brandDesc=LG&modelDesc=REFRIGERATOR&blt=11
Thanks for choosing FixYa.
Kelly
Sep 19, 2010 | LG LSC26905TT Side by Side Refrigerator
My LG ice maker water is very thin? it talkes a
They usually have a filter in the inlet at the back of the fridge, check that and replace.
Sep 23, 2009 | Refrigerators
Water collects in bottom of freezer, then it runs out in the floor after ice has filled the bottom of the freezer. I have a frig with water and ice in the door. The ice maker is working fine, but the water...
there is a chance that the bottle that holds your water in the fridge compartment.could be broken or a line maybe disconnected this would cause water to leak in the fridge compartment.this bottle is designed to hold the water and get it cold before dispensing to your glass
Sep 16, 2009 | Refrigerators
Kitchen aide ksrg22ftss fridge wont make ice and
check your fill solenoid located at the bottom back of fride the valve may have a verry fine filter inside the valve ether clean it or replase the valve valve cost aprox 20,00 thanks from gilles
Mar 15, 2009 | Refrigerators
Smelly water from door dispensor
I had the same problem. Drove me crazy and cost me about 5 filters at $50 a pop until I found the solultion. Water in the Sears/LG refrigerator that I have (french door trio) goes through the filter then into a container on the left front door of the refrigerator. That container stores the water so it can get cold and it also equalizes the flows in the system so that when you put your glass under the spigot the flow is steady and the water is cold. Problem is .... this tank can build up with algae/slime/foul tasting stuff. Since it is after the filter, no matter how many times you change the filter it will have no impact on the water in this container. That is why if you use the water spigot a lot, the water seems to get a little better (as the tank water gets diluted) but as soon as you don't use it for several hours or more, back comes the smelly water again. Solution for me was to remove the plastic panel on the inside of the left front door and clean the plastic bottle. It is pretty easy to remove with 2 screws and easy to pull off the hoses. I filled is with a little clorox and water and swished it around for several minutes then drained and rinsed it. Then I filled it again with a little clorox (like an ounce or two max) and put the container back into the fridge. Once in the fridge, I ran fridge water through the front water dispenser for about a gallon or so. This flushed out the chlorine in the plastic container as well as the lines between the container and the spigot. After about a half hour of work, my great tasting water in the fridge is back again. I've checked the taste on this water for several weeks now and no plastic/odor/bad tasting water any more. Hope this helps.
Oct 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge freezer door ice maker
the ice maker controls the seloniod the icemaker wire arm must be all the way down .just because the seloniod test good doesnt mean the valve seat isnt stuck the water valves open by your house water pressure if your filter is dirty this can also lower the pressure if the icemaker module is bad this also can cause it if you pull the front of the ice-maker off you will se a bunch of holes if you get a piece of 10 Gage house strip about 1/4 inch off either side and insert it into the holes marked t and h that will test cycle the ice maker they will be close together don't get shocked if the ice maker cycles and doesnt fill and the ice maker fill tube isn't frozen replace the water valve if the ice-maker doesn't cycle replace the brown motor module
Jan 09, 2008 | Jenn-Air JCD2389G Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
255 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
