Question about Fantom Vacums FM780 Twister 700LX Upright Vacuum
Power goes on and off while in use
My Fantom FM780 will power itself on and off while vacuuming. It's probably a loose power connection, but I don't know where to look... can you help?
  • 61 Answers
There really isnt anywere on that machine for a "loose" power connection. You probally have a short in the electrical wiring. Your local vac shop should be able to locate the short and replace the wire.
Posted on Apr 17, 2009
I need to download a manual for this product
enter product info at sech area ,find a provider then submitt make and model # asking for user manual
Jul 09, 2011 | Fantom Vacums FM780 Twister 700LX Upright...
How do I get a manual for the Fantom Twister FM780?
I just uploaded the manual for the FM760 Twister to http://homeappliance.manualsonline.com/
I believe this one is similar enough to the FM780 to be of use to you. It should be available soon.
Mar 04, 2011 | Fantom Vacums FM780 Twister 700LX Upright...
Same issue...need replacement wand for fantom lightning
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested
Aug 09, 2009 | Fantom Vacums Lighting Canister Vacuum
Nedd power head wand for Fantom Model BPSRLC51
the best bet would be to look on ebay. the fantom line was discontinued
Jul 28, 2009 | Fantom Vacums Lighting Canister Vacuum
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Fantom Canister Vacuum parts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12055&thid=723654
Posted by jaybird73 on Jun 30, 2008
Hi, Don. I'm in need of a part for my Fantom Canister. It's a little difficult for me to describe but here goes...the part is the small metal "pins" that are found in the connection between the hose and the motorized floor attachment. There are normally 2 found in that area, they are about an inch long and I guess they pass the electricity between the hose and attachment. Any help is appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sound so me that it could be a lower wand with the pins in the end or the part of the power nozzle and the part that the lower wand fits into is called the gooseneck and that can be replaced as well. If it is part of the hose then you may have to replace the hose and that could be expensive or over $100.00 or more, as an estimate. The best place to get the information is the owner’s manual under trouble shooting or to cal the Fantom factory of which I will provide for you @ the bottom; or your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Fantom Vacums Lighting Canister Vacuum
Fantom fury vacuums
Most power heads have some screws from the bottom to take out, the the top comes off, then you can get to the belt.
Feb 07, 2008 | Fantom Vacums Lighting Canister Vacuum
Fantom fm760
You may have a loose connection somewhere, or maybe a bad cord.
Dec 19, 2007 | Vacuums
Fantom Vacums FM780 Twister 700LX Upright Vacuum Logo
93 people viewed this question
Top Fantom Vacums Vacuums Experts
woodzowl307
ray gallant
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
