Question about Car Audio & Video
Code needed radio code vivaro sportiff
  • 47 Answers
First of all take out the headunit and see if its written on it anywere if not then only thing to do is to take it to a local car audio dealer and they will decode it for you :)
hope this helps
Upfront Audio
Please rate and leave feedback :)
Posted on Apr 24, 2009
My opel vivaro van on 7 safe and I pressing the as button and on and wont give me the ----
You must leave the radio ON like this until the SAFE mode clears.
When it does, to get the code accepted, press AS and then a couple of seconds later the 'on' button, together until it beeps.
As you know you will then see 4 dashes. Each dash is a number from your code.
Use the numbers along the radio (1 is first number in code, 2,3 and 4 the other numbers and so on)
As an example, if your code was 4432
press button '1' 4 times (gives a 4)
button '2' 4 times (gives a 4)
button '3' 3 times (gives a 3)
button '4' 2 times (gives a 2).
When you see your code displayed correctly on the screen press AS until you hear a beep.
HELP Radio SAFE mode
May 14, 2016 | Opel Cars & Trucks
After serviceing injector pump for opel vivaro CDTI 1.9 2003
NO START OPEL VIVARO FIX - YouTube
? 3:39
www.youtube.com/watch?v=i_G7Al9IFuU
Jan 21, 2014 - Uploaded by anto denn
All it does is crank but as soon as you fiddle with the injector ...Help have a 2003 trafic drove fine then one day i drove 100 yards and it just ... is the fuel pump turning on when you turn the key ?... Vauxhall Vivaro 2 0 CDTI Turbotune tuning box fitting guide - Duration: 6:40. by Darren Darling 28,094 views.
Sep 28, 2015 | Opel Cars & Trucks
Reset service light on opel vivaro van
use a code reader to reset the CPU
Dec 31, 2013 | 2007 Opel Vivaro 1.9
How do i enter the radio code in my vauxhall vivaro
The code entry instructions depend on the radio MAKE + MODEL<br /><br /><br />Find them here on this free website<br /><br />www.radio-code.co.uk/code-entry-help.php<br /><br />
Aug 24, 2010 | Car Audio & Video
Trying to fit Parrot MKi9200 to 2008 vivaro but screen blank
check there is an ignition supply, newer vivaro's did not have an ignition supply at the radio and you will have to run a wire from the parrot to the fuse box at the end of the dashboard, this will be yellow wire. If you are in doubt contact a parrot engineer from parrot.com
Jun 12, 2010 | Parrot Mk6000 Bluetooth Hands Free Kit
Need code for my cd player in my vauxhall vivaro,cdr 2005. gm020543516920
Unfortunately the majority of SIEMENS/VDO codes
(including your CDR2005) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database…which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
Mar 30, 2010 | Car Audio & Video
My battery died in my Vauxhall Vivaro van.. I have the Bulk standard radio/cd player in there. When the battery went we tried bump statring the van and (basicaly) I had lights goin on and off all over the...
This is a safty feature of most factory car radios, if the power is turned off it thinks its being stolen so you need to put in a code which is normally unique to that radio. Most of the time the maker of the car will put the pin number in the car manual, but if your like me i dont have it anymore and found it was cheaper (and easier) to fit a new stereo.
Jan 03, 2010 | OEM Systems Car Audio & Video
How do i enter the radio code on an opel vivaro van
Hi just this second fixed mine. Turn on ignition then turn radio off press and hold the AS button and keep it depressed while turning radio on. The display will now show a number for how many attempts you have and 4 dashes. press button number 1 till the first digit of youe code is displayed ,then button number 2 again till the second digit of your code is displayed and repeat with number 3 and number 4. when the correct code is displayed push and hold the AS button and keep depressed while turning radio on (basically a reverse of what you did to access input code screen.you will hear a beep, the screen will recall its memory takes abbout 20 seconds then your good to go... Hope this helps.
Jan 30, 2009 | Car Audio & Video
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
