Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Faded screen from top to bottom in middle,I replaced the lamp
Replaced lamp and now have spot from top to bottom of middle of screen
  • joenmar Apr 17, 2009
    This was my second lamp in 2 years
I had an authorized Sony repairman come to my home. I'm sorry that I cannot remember the part that needs replacing but I can tell you that it cost $700+ and $200+ for labor. We would be stupid to replace it instead of buying a new TV. I doubt I will invest in another Sony as this is a known and common problem with these TV.
Posted on Apr 27, 2009
Turned on my Element FLX 3210 32" TV this morning. When it powered on, there was a black spot in the middle of the screen that reached from the top of the screen to the bottom. The left and right...
there are 2 capacitors on the power board that need replaced with exact replacements. They will be labeled ec17 and ec18 on the power board. The caps themselves will probably be brown or black and say 10uF 450v on them. You should be able to get the parts at radio shack or digikey or mouser. You will also need a solder gun and some solder. Check youtube on how to solder and always remember to unplug the TV before servicing.
Dec 21, 2010 | Element Electronics FLX3210 32 in. LCD TV
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes about half way down the screen.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Dec 06, 2009 | Zenith D52WLCD 52" Rear Projection...
Blue spots on screen.
Sounds like your light engine is going bad. I would have it verified by a service tech.
Oct 02, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Sep 25, 2009 | Zenith D52WLCD 52" Rear Projection...
Green spot in middle of image as though a spot light was shinning on the screen. I've replaced the lamp
Welcome to LCD 101, the blue device is dying in the projector. Replace product with dlp brand and it will last a lifetime. good luck
Apr 14, 2009 | Epson PowerLiteĀ® 1700c LCD Projector
Fading down the middle
Lower then remove rear door.
Lift the two blue tabs , remove the fuser and inspect the top roller
Jan 29, 2009 | HP LaserJet 4250n Printer
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
127 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
