Question about Kitchen Ranges
How do I replace heating element
Dual element broken. I need to know how to replace it.
  • 1 more comment
  • tfdret Apr 25, 2009
    I need to know how to lift the top on a ceramic kenmore range
  • tfdret Apr 26, 2009
    Kenmoore electric range model # 790.96214408.
  • Anonymous Apr 30, 2009
    I need to know how to lift the ceramic top on the kenmore 790 electric range?
  • 81 Answers
Some just lift and plug in. Some are connected by wire leads. If it is an open top range, just (for the most part) lift from he opposite end of the connected side and pull it out. On others, the range top must be lifeted up to expose the elements, visual insepction will tell you whether it is "plug in" or connected by wire leads. WHATEVER YOU DO, MAKE CERTAIN THAT YOU HAVE SHUT THE POWER SUPPLY OFF AT THE BREAKER. If it is connected by wire leads, they could be "slip on" terminals, requiring a pair of pliers to separate them and a few are just screw terminals. Most elements are just seated without being afixed by screws or anchors of any type.
Posted on Apr 25, 2009
How can I tell if my water line tank heating element is broken? Should it get warm to the touch?
no it should not. If fridge fan is working water should not freeze.
check for fan motor operation.
Apr 03, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
Hoover f7411-900 steamvac dual v, water heating unit repair
The element is burned out or the sensor is shot. When there is no water present a sensor is supposed to turn off the heating coil. This sensor is most likley fail safe, meaning if it is broken it wont turn on the heat because it doesn't know if there is water or not. Or the coil itself is fried. Somtimes running it for too long, or on a long extension cord will cause them to fail.
Oct 08, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
My 4 slice dual it keeps popping the breaker
One of the heating element is broken and the heating wire which have live electricity is touching the body of the toaster and thus the poppong of the breaker. So you can use this link and check which is the broken heating element . You can buy one or more heating element from ebay there are only two kinds CENTER and END which you have choose from, they will aslo supply aslo replaceing instructions.
Dec 07, 2011 | Dualit 40352 4Slice Toaster
Control for dual element has to be wiggled just so -so to shut element off, what do I need to fix it? Heats perfectly, shutting it off is my only problem.
The control you're wiggling (infinite switch)needs replacement. Model# and the position of the dual element (right or left, rear or front) is needed to get the part number.
Mar 03, 2010 | Cooktops
The centre element in my 4 slice model has gone. Can this be replaced?
Don't know if you can get the heating element as separate part. But, this can probably be repaired. It's likely either a burned connection/connector or the heating element is broken.
Bad connectors can be replaced, the heating element can be just twisted back together where it is broken.
Charlie
Aug 14, 2009 | Dualit CTS4E 4-Slice Toaster
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Electric Heating Element Not Heating stove
It's not a fuse, but a wire or heating element has burned up. Please TURN OFF the circuit breaker until you repair the problem, or at least until you know what the problem is! You say "in" the stove, so I'm assuming that you mean in the oven. Whichever element it is, whether it's in the oven or on the stovetop, just needs to be removed and checked for continuity with an ohmmeter. Quite frankly, if it IS an element, then you should see a burned-out spot somewhere on it that's pretty obvious. Then you just need to replace the element. If it's a wire, then you will need to repair the wire so that it safely makes contact with the element again. That process is a little more involved than just replacing an element, but let us know what you find. I can describe a wire-repair procedure if need be. ;)
Aug 13, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Kitchen Ranges Logo
326 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
